-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   ideasUnvToFoam behavior in 1.6-ext vs. 2.1.x (http://www.cfd-online.com/Forums/openfoam-pre-processing/118938-ideasunvtofoam-behavior-1-6-ext-vs-2-1-x.html)
chaz June 6, 2013 21:42
I have been using ideasUnvToFoam for some time to convert meshes generated in Salome to use in openFoam 2.1.x.
I recently began using 1.6-ext, and the behavior of ideasUnvToFoam is different, and crashes.
When converting a simple mesh which has two face groups and two volume groups defined in Salome, I get:
Sorting boundary faces according to group (patch)
--> FOAM FATAL ERROR:
4629 not found in table.  Valid entries:
4110
519
520
521
... etc. etc....
4628
    From function HashTable<T, Key, Hash>::operator[](const Key&)
    in file /home/miner/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/HashTableI.H at line 111.
The mesh converts fine in openFoam 2.1.x's ideasUnvToFoam.
Does anyone know the differences, or if 1.6-ext's version can be updated, or modified to fix this issue?
Thanks
