Home > Forums > OpenFOAM Pre-Processing
laplacianFoam
Old   June 9, 2013, 18:21
Default laplacianFoam
Evangelos
Danath is on a distinguished road
Hello !
I made the following geometry and now i want to calculate the entropy production.
i want to set periodic boundaries at left, right
i make the geometry with desighmodeler and then i convert to openFoam using fluentMeshToFoam *.msh
i set the left boundary as inlet and the right as outlet .
Next step ?
Danath is offline   Reply With Quote
Old   June 10, 2013, 12:54
Evangelos
if i set inlet and outlet as cyclic will work ?
Old   June 10, 2013, 13:50
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Evangelos,
Uhm... "entropy production"? I don't think you can do entropy calculations with just laplacianFoam... it's a very basic "temperature transport" solver, so there aren't any specific material properties in it.
Unless you want to calculate entropy purely based on temperature!? If so, do you have an equation to solve this relation between temperature and entropy?
As for the periodic boundaries, it depends on the exact nature of what you want to do. Because "Cyclic" boundaries are usually just cyclic: they sort-of enable matter teleportation from one patch to the other.
If you provide a bit more description of the kind of simulation you want to perform, it'll be easier for people to help you.
Best regards,
Bruno
Old   June 10, 2013, 14:55
Evangelos
Hello !
Forget entropy production and laplacianFoam
At first i want to make periodic boundaries for inlet and outlet
so i modify boundary,P and U (see pixtures)
but when i try to run for example icofoam i find errors
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for cyclic symmetry1
Is your field uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: /home/danath/OpenFOAM/danath-2.1.0/run/tutorials/test/0/U::boundaryField from line 25 to line 40.
From function GeometricField<Type, PatchField, GeoMesh>::
GeometricBoundaryField::GeometricBoundaryField
const BoundaryMesh&,
const DimensionedField<Type, GeoMesh>&,
const dictionary&
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 271.
FOAM exiting
When i type foamUpgradeCyclics
Create time
Reading boundary from "/home/danath/OpenFOAM/danath-2.1.0/run/tutorials/test/constant/polyMesh/boundary"
Detected 0 old cyclics.
No changes made to boundary file.
Time: 0
Loading field p
No changes made to field p
Loading field U
No changes made to field U
what should i do ? i am very confused ?
Old   June 10, 2013, 15:00
Bruno Santos
Hi Evangelos,
Instead of editing the "boundary" file directly, use createPatch instead: http://openfoamwiki.net/index.php/CreatePatch - you should find some more ideas on this topic on that page.
Best regards,
Bruno
Old   June 10, 2013, 15:03
Evangelos
also for P and U
Old   June 10, 2013, 15:04
Evangelos
thanks a lot !
Old   June 14, 2013, 06:07
Evangelos
Hello ! Finally i create periodic boundaries
I figured the diffusion and now i want to calculate the entropy production .
I have the equation !
can somebody help me ?
Old   June 16, 2013, 12:09
Bruno Santos
Hi Evangelos,
Sorry, but I'll have to be quick. Here are the steps I suggest that you follow:
  1. Do this tutorial first, so that you can learn the basics of modifying a solver: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
  2. Then read the following post: adding "h" field to sonicFoam post #11 - study those instructions and adapt to the calculation you want to perform.
    • Keep in mind that the file "eEqn.H" does not exist in your case, but from the information you learn from the previous tutorial, you should be able to figure out where to place the equation for calculating the entropy production.
Beyond this, it probably depends on the equation you have got.
Best regards,
Bruno
Old   June 17, 2013, 04:56
Evangelos
thanks a lot !
Old   July 14, 2013, 08:00
maalan is on a distinguished road
Hi there!!
I am interested in modifying the laplacianFoam application. Once done the tutorials recommended, I would like to create my application to solve the laplace's equation in a domain (laplacian (phi) = 0). How I should proceed?? I have noticed the laplacian function in laplacianFoam.C has 2 inputs and I have just one scalar function, phi.
Thanks a lot!!
maalan is offline   Reply With Quote
Thread Tools
Trackbacks are On
laplacianFoam run-time error industrial0503 OpenFOAM Running, Solving & CFD 2 June 6, 2012 14:16
Add temperature-varying diffusivity in laplacianFoam tianyikillua OpenFOAM Running, Solving & CFD 0 March 28, 2012 17:00
Serious error in calculating gradT (laplacianFoam) doubtsincfd OpenFOAM Bugs 1 December 30, 2011 03:56
create own case for laplacianFoam rahulrp OpenFOAM Pre-Processing 6 April 8, 2010 00:03
laplacianfoam with solidification dakos OpenFOAM 1 November 14, 2009 07:15
