mosquera |
June 28, 2013 10:49 |
Realisable K-Epsilon Model in a Channel
I've been struggling with modelling a flow through a channel. I have it set up as a two dimensional flow.
My objective is to model the flow using a realisable k-epsilon model. I've mapped experimental values at the inlet. I'm using simpleFoam for this. Unfortunately, I can't get the model to converge.
Within my model, SymmWall is the boundary at the top "wall". The boundary layer has been tripped in the flow and so I am using a symmetric boundary condition (I am not sure, but I have been assured by my advisor this is the correct method.
Inlet and Outlet refer to the inlet and outlet.
Wall refers to the bottom wall across which the flow is moving.
Anyway, on to my initial boundary conditions:
U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
SymmWall
type symmetryPlane;
Wall
type fixedValue;
value uniform (0 0 0);
Outlet
type zeroGradient;
Inlet
type timeVaryingMappedFixedValue;
setAverage 0;
perturb 1e-05;
offset (0 0 0);
frontAndBackPlanes
type empty;
k
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1.5e-09;
boundaryField
Wall
type kLowReWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 8.1323e-04;
Outlet
type zeroGradient;
Inlet
setAverage 0;
perturb 0;
offset 0;
frontAndBackPlanes
type empty;
SymmWall
type symmetryPlane;
epsilon
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.0008123;
boundaryField
Wall
type epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.0008123;
Outlet
type zeroGradient;
Inlet
setAverage 0;
perturb 0;
offset 0;
value uniform 0.0008132;
SymmWall
type symmetryPlane;
frontAndBackPlanes
type empty;
Also, here is my current fvschemes file. The goal is to have the solution be of second order.
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
k Gauss linear;
epsilon Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,k) Gauss linearUpwind grad(k);
div(phi,epsilon) Gauss linearUpwind grad(epsilon);
div(phi,T) Gauss linear grad(T);
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
interpolate(T) linear;
interpolate(epsilon) linear;
// interpolate(omega) limitedLinear 0 1000000;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
checkMesh yields that my mesh is OK. The mesh was imported from Gambit.
I could additionally attach the mapped values if anyone feels that neccesary. Are there any values I should be on the lookout for there? I'm already positive there's no zeros anywhere in those files.
Again, any assistance would be appreciated. I've been working at this for a couple of days now.
Thanks,
Matt
