Yaw Boundary Conditions
Old   August 10, 2013, 11:13
Default Yaw Boundary Conditions
Luca
LM4112 is on a distinguished road
Dear all
I was thinking to simulate the yaw angle of a body by adapting the BCs instead of rotating the CAD model. My model is a body in a wind tunnel where all walls (except the moving ground) are fixed. Do you think that is correct if I use inlet-outlet BCs on the side walls simulate a side wind? I think that the boundaries that I have change are:
-inlet and outlet (add transversal velocity)
-side walls of the wind tunnel (use inlet-outlet boundary condition to simulate the side wind)
best regards
Luca
LM4112 is offline   Reply With Quote
Old   August 16, 2013, 07:41
Retired Super Moderator
Bruno Santos
Hi Luca,
Have a look into these tutorial cases:
  • "incompressible/simpleFoam/motorBike"
  • "incompressible/pisoFoam/les/motorBike"
They basically simulate the flow around a motorbike as if it were inside a wind-tunnel... or outside on the street... I can't remember which one it is
Best regards,
Bruno
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
