Home > Forums > OpenFOAM Pre-Processing
Problems configuring a case with a converted axisymmetric mesh
Old   August 14, 2013, 07:49
Default Problems configuring a case with a converted axisymmetric mesh
sonu
yash.aesi is on a distinguished road
helo bobi ,
i converted my 2D axisymmetry fluent mesh into OF and then changed the 0 folder according to my values also i checked mesh with checkmesh command its ok but when i tried to run it run it is giving me following error , can you please help me how to overcome from this error ?
FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
patch type symmetryPlane and patchField type empty
file: /home/yash/OpenFOAM/yash-2.2.0/run/tutorials/compressible/rhoCentralFoam/exsercisePrb/0/p.boundaryField.Axis from line 39 to line 39.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 165.
yash.aesi is offline   Reply With Quote
Old   August 14, 2013, 08:54
immortality's Avatar
Ehsan
immortality is on a distinguished road
Originally Posted by yash.aesi View Post
helo bobi ,
Hi
attach your p file here.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 14, 2013, 11:24
Bobi
babakflame is on a distinguished road
Hi
It seems that you have problem with your patch type definition. In the tutorial Tobi has defined a wedge typed mesh and has set consistent pressure types for different patch types. your problem is a tiny one. Just take a deeper look into the defined patch types in Tobi tutorial. Although my suggestion is making a wedge-typed mesh instead of a plane.
Good Luck
Bobi
babakflame is offline   Reply With Quote
Old   August 14, 2013, 14:27
sonu
here is my p file of 0 folder please have a look ....
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
fuel_inlet
type zeroGradient;
coflow_inlet
type zeroGradient;
Outlet
type zeroGradient;
Axis
type empty;
Upperwall
type zeroGradient;
frontAndBack
type empty;
Old   August 14, 2013, 14:38
sonu
helo bobi ,
In my boundary file under polymesh (constant ), the axis is defined as the symmetric plane after my geometry conversion . Now should i write same symmetric plane in each variables in the 0 file for the axis .
thanks alot for your cont. help
Old   August 14, 2013, 15:58
Ehsan
Sonu my guess was right,you should set axis type in p file as symmetryPlane not empty if its really symmetryPlane.
Old   August 15, 2013, 11:26
Bobi
Hi Sonu
As ehsan has hinted; the types of boundaries in boundary file , even the names (upper letters or not) must be the same as what you set for
flow variables as like pressure. Although I think you have solved it by now.
Bobi
Old   August 16, 2013, 09:32
sonu
helo bobi,
actually my mesh is in cm and now i think i need to convert it into m , so as per my knowledge i have to use command transformPoints '(0.01 0.01 0.01)' but when i am giving this command then its giving the error :
Usage: transformPoints [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-noFunctionObjects
do not execute functionObjects
-parallel run in parallel
-region <name> specify alternative mesh region
-rollPitchYaw <vector>
transform in terms of '(roll pitch yaw)' in degrees
-roots <(dir1 .. dirN)>
slave root directories for distributed running
-rotate <(vectorA vectorB)>
transform in terms of a rotation between <vectorA> and
<vectorB> - eg, '( (1 0 0) (0 0 1) )'
-rotateFields read and transform vector and tensor fields too
-scale <vector> scale by the specified amount - eg, '(0.001 0.001 0.001)'
for a uniform [mm] to [m] scaling
-translate <vector>
translate by the specified <vector> - eg, '(1 0 0)'
-yawPitchRoll <vector>
transform in terms of '(yaw pitch roll)' in degrees
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.2.0 (see www.OpenFOAM.org)
Build: 2.2.0-b363e8d14789
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
can you please tell me whats wrong here ?? thanks a lot for your continuous help
Old   August 16, 2013, 09:39
Tom Fahner
tomf is on a distinguished road
Send a message via MSN to tomf Send a message via Skype™ to tomf
The usage would be:
transformPoints -scale '(0.01 0.01 0.01)'
Regards,
Tom
tomf is offline   Reply With Quote
Old   August 16, 2013, 09:42
sonu
thanks a lot Tom i will try with this .....
Old   August 16, 2013, 12:56
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
FYI: Given that the topic of questions had changed from the original thread libOpenSMOKE (from right after the post #208), I've moved the posts above to this new thread you are currently reading.
edit: and moved the question about rhoCentralFoam to here: Slow run with rhoCentralFoam
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
Problems converting a Fluent case file McFly OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 10 August 1, 2013 21:41
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
