[swak4Foam] problem with groovyBC
Old   August 28, 2013, 14:42
Default problem with groovyBC
Jonathan is on a distinguished road
hi guys,
i was hoping someone could give me a hand with the following issue i am having with groovyBC???
below is my groovy "code":
    INLET
    //type        fixedValue;
    //value        uniform (0 0 21.38);
        type            groovyBC;
    lookuptables (
        name z_velocity;
        outOfBounds clamp;
        fileName "$FOAM_CASE/rel_z_velocity";
        name y_velocity;
        outOfBounds clamp;
        fileName "$FOAM_CASE/rel_y_velocity";
        name x_velocity;
        outOfBounds clamp;
        fileName "$FOAM_CASE/rel_x_velocity";
    variables    "radius=sqrt(pow(pos().x,2) + pow(pos().y,2));theta=asin(mag(pos().x/pos().y));";
    valueExpression    "vector(x_velocity(radius)*sin(theta),y_velocity(radius),z_velocity(radius))";
        value        uniform (0 0 0);
and this is the error message i am getting!
#0  Foam::error::printStack(Foam::Ostream&) in "/home/jonathan/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/jonathan/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  asin in "/lib/x86_64-linux-gnu/libm.so.6"
#4  Foam::asin(Foam::Field<double>&, Foam::UList<double> const&) in "/home/jonathan/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::asin(Foam::UList<double> const&) in "/home/jonathan/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  parserPatch::PatchValueExpressionParser::parse() in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#7  Foam::PatchValueExpressionDriver::parse(std::string const&) in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#8  Foam::CommonValueExpressionDriver::evaluateVariable(Foam::word const&, Foam::string const&) in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#9  Foam::CommonValueExpressionDriver::addVariables(Foam::string const&, bool) in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#10  Foam::CommonValueExpressionDriver::addVariables(Foam::List<Foam::string> const&, bool) in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#11  Foam::CommonValueExpressionDriver::clearVariables() in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#12  Foam::groovyBCFvPatchField<Foam::Vector<double> >::updateCoeffs() in "/home/jonathan/OpenFOAM/jonathan-2.1.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so"
#13  Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/home/jonathan/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/SRFSimpleFoam"
#14
 at SRFSimpleFoam.C:0
#15
#16  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#17
Floating point exception (core dumped)
Any ideas???
many thanks in advance,
best regards
jon
Jonathan is offline   Reply With Quote
Old   August 28, 2013, 14:56
Assistant Moderator
Bernhard Gschaider
Originally Posted by Jonathan View Post
hi guys,
<snip>
<snip>
Any ideas???
best regards
jon
Let me quote from the man-page of asin:
asin(x) returns a NAN and raises the "invalid" floating-point exception for |x| > 1.
groovyBC does not check whether you use the functions correctly. Probably your |x/y|>1
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 3, 2013, 14:50
Default thanks
hi Bernhard,
yes thanks - that was it. i had a asin instead of an atan which was a pretty dumb mistake, and was throwing me off
thanks for your help + a great tool,
best regards
jonathan
groovybc, swak4foam
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
[swak4Foam] epsilon groovyBC problem Thom OpenFOAM Community Contributions 5 October 26, 2012 05:16
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
