Solid-air flow domain
Old   September 26, 2013, 06:29
Default Solid-air flow domain
Mominul MuKuT
mukut is on a distinguished road
I want to simulate flow induced by plasma actuator. That's why I need to create following geometry as shown below:
How can I define such solid and gas (air) domain?
Thanks in advance.
mukut is offline   Reply With Quote
Old   September 26, 2013, 12:48
Jace
zhengzh5 is on a distinguished road
Thanks in advance.
hey, check out chtMultiRegionFoam, you can define solid/fluid by specifying the material properties in constant/transportProperties. This gives you an idea of how to get up multi region mesh. Note that chtMultiRegionFoam is for conjugate heat transfer simulations, so the solver itself is not directly applicable to you, you will need to remove the heat components and add on the electromagnetic forces parts in order to simulate the plasma generation (not sure how to go about doing that.)
Anyways, that should at least help you figure out the mesh part.
Regards,
Jace
zhengzh5 is offline   Reply With Quote
Old   September 26, 2013, 20:19
Mominul MuKuT
Regards,
Jace
Thanks for your reply. I have checked chtMultiRegionFoam/ chtMultiRegionSimpleFoam but where is transport properties Dict? I have found /constant/regionProperties where region is identified for the patches used
and in /system/topoSetDict the regions are defined in details with co-ordinates, I am reading an explanation about toposet
cheers.
Old   September 27, 2013, 02:47
Christoph Kratzsch
PonchO is on a distinguished road
cheers.
Hi mukut,
take a look in the thermophysicalProperties-Dict. If you look in the heatExchanger-tutorial the density for the solid is set to 1000 in the densityCoeff subDict.
I don't have used the thermophysicalProperties already, but i think its just an extension of the transportProperties-Dict.
Best regards,
Christoph
PonchO is offline   Reply With Quote
Old   September 27, 2013, 07:04
Mominul MuKuT
Originally Posted by PonchO View Post
Hi mukut,
Best regards,
Christoph
Thanks bro. I am reading and hope will get some ways to solve it...
domains, geometry generation, plasma actuator modeling, pre-processing
Cross Flow cooling system involving multiple fluids and a solid domain ajaymenon CFX 4 March 8, 2012 17:00
Simulation of a Silo Attesz CFX 20 October 15, 2010 08:11
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
