September 24, 2013, 07:31 |
Errors on fvSolution and fvSchemes
Gabriel de PInho RImoli
Hello folks!!
What's up ?? So,I'm doing a case using a chtMultiRegionFoam solver and it happens that after I run the terminal,the arquives fvSolution and fvSchemes under my system directory gets empty(no matter what I write there,the terminal get's it empty).What I am doing wrong?? |
September 28, 2013, 09:10 |
Nima Samkhaniani
Rep Power: 24 |
well, its OK , after split mesh, it creates several empty fvSolution and fvSchemes for each region, you nead to modified it ,then run it
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
Negative alpha1 using interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 14 | March 2, 2013 10:26 |
how to do the fvSolution configuration - SIMPLE Foam - complex cylinder geometry | despaired student | OpenFOAM Running, Solving & CFD | 10 | July 5, 2012 03:36 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Very high courant number, time step continuity errors and bounding epsilon | erncyc | OpenFOAM Running, Solving & CFD | 1 | March 24, 2011 11:00 |
General help for fvSchemes and fvSolution settings | harly | OpenFOAM Running, Solving & CFD | 4 | September 7, 2009 10:31 |
