boundary conditions
Like Tree1Likes
  • 1 Post By Bernhard
Old   September 29, 2013, 15:28
Default boundary conditions
mohsen kh
m5m5kh is on a distinguished road
hi dear foamers
I want to add a boundary condition as below
what should I do?
best regards
Mohsen
m5m5kh is offline   Reply With Quote
Old   October 1, 2013, 00:47
Unhappy
mohsen kh
no one knows about this boundary condition?
Old   October 1, 2013, 03:46
Bernhard
Bernhard is on a distinguished road
What is T_g? Have a look at the "mixed" boundary condition, or otherwise groovyBC, which is built on that boundary condition.
Bernhard is offline   Reply With Quote
Old   October 1, 2013, 03:57
mohsen kh
Hi Bernhard
I try to install swak4foam to use groovy bc on my openfoam 2.2.0
I install bison 3.0 but when I write wmake all but error " permission denied" happens.do I have to install flex too?
Old   October 1, 2013, 04:17
Bernhard
Originally Posted by m5m5kh View Post
Hi Bernhard
Please look in the help file on how to install swak as a non-root user.
DaSh likes this.
Old   October 1, 2013, 08:28
Olivier
olivierG is on a distinguished road
hello,
You also may take a look at the "externalWallHeatFluxTemperature" boundary condition, which does what you want.
regards,
olivier
olivierG is offline   Reply With Quote
Old   October 1, 2013, 10:41
mohsen kh
Hi dear Olivier
where and how should I define h and Ta and q ???and what does it mean by "q"?while my aim is to calculate q ????? I got confused by this boundary condition
k(dT/dx)=h(T-Tinf)
this is my boundary condition at wall
would you please describe this bc in detail
best regards
Mohsen
Originally Posted by olivierG View Post
hello,
regards,
olivier
Old   October 1, 2013, 10:54
Olivier
hello,
take a look at "$FOAM_SRC/turbulenceModels/compressible/turbulenceModel/derivedFvPatchFields/externalWallHeatFluxTemperatureFvPatchScalarField. H"
You will find all you need in this header file.
regards,
olivier
Old   October 1, 2013, 13:54
mohsen kh
I saw that but my model is incompressible and laminar.Are you sure I can use this bc?
hello,
regards,
olivier
Old   October 2, 2013, 01:55
mohsen kh
my problem is already unsolved
I can not install swak4foam
I have OF 2.2.0
bison 3.0
flex 2.5.33
please help me step by step
I tried as readme but no success was gained
best regards
Mohsen
Old   October 2, 2013, 04:41
Olivier
hello,
About the externalWall... bc, this depend of your solver. For a wall, try the banana bc, you will get an error with all possible bc.
If externalWal... is not here, then go with swak.
regards,
olivier
Old   October 2, 2013, 04:56
mohsen kh
hello,
regards,
olivier
I did all the things you said olivier and I need to use swak4foam,do you have any experience about installing swak4foam for OF 2.2.0?
I can not install it when I use ./Allwmake it says: permission denied
what should I do?
thanks
Mohsen
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
