Boundary condition analysis for turbomachinery
Old   November 1, 2013, 05:15
Default Boundary condition analysis for turbomachinery
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi there,
I am working on axial flow fan, its an annular case.
I am using OpenFOAM for my simulation.
I have give the BC, as discribed in the user manual
inlet - massflow or velocity (fixed value)
outlet - fixedValue (0), I know its not wrong, however we are forcing the pressure to zero at outlet face, so I want to say its not an appropriate one.
Then, I have given a try to fixedMeanValue (0) at outlet for pressure, it seems the result which I obtained from this BC is reasonably fine. however I want to check the deviation from the radial equilibrium solution. I am bit confused here to get the analytical solution for radial equilibrium condition. dp/dr = rho *v^2/r
v --> swirl velocity
r --> radius
my question is:
how can I get the swirl velocity?
can you people give a hit to solve the problem?
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   November 4, 2013, 03:46
Antonio
avigrod is on a distinguished road
Originally Posted by sivakumar View Post
Hi there,
r --> radius
my question is:
Thanks,
Sivakumar
I guess there are better and easier options in paraFoam for getting Vu, but I would try in this two ways:
1) Getting Vx, Vy and Vz in the disk rotor by using a sampleDict* (and also angular position/velocity of the rotor if not steady), and calculating Vr, Vu and Vx by hand in Octave/Matlab/Python whatever...
2) Writing a function Object for defining a coordinate transform tensor which moves Cartesian coordinates to cylindrical within the rotor disk.
avigrod is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
