-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   OpenFoam Running in parallel (http://www.cfd-online.com/Forums/openfoam-pre-processing/125937-openfoam-running-parallel.html)
Salam-H November 4, 2013 14:05
1 Attachment(s)
Hi every one, I hope someone can help. I am trying to run openfoam in parallel. I have 8 processor in the decomposepar when I run it I get the following error massage , I would be grateful if someone tells how to fix it.
the shape I have is funnel. however when I use a cubic shape I dont get any error every thing goes well. I modified the dambreak case.
best regards,
Salam
nimasam November 7, 2013 14:45
it seems your solution is diverging :) and it is not related to your parallel set up, could you run it in serial?
P { margin-bottom: 0.08in; } Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 1.2000578e-06
