splitMeshRegions doesn't find my regions.
Old   November 13, 2013, 09:06
Default splitMeshRegions doesn't find my regions.
GPesch is on a distinguished road
I am trying to set up a very simple multi region case to test a solver I am working on.
The problem is that when I run "splitMeshRegions -cellZones -overwrite" I will always get the output
"Only one region. Doing nothing".
I defined a cubic block with blockMesh, which worked fine. Here's the blockMeshDict:
convertToMeters 1;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 1)
    (1 0 1)
    (1 1 1)
    (0 1 1)
blocks
    hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1)
edges
boundary
    maxY
        type wall;
        faces
            (3 7 6 2)
    minX
        type patch;
        faces
            (0 4 7 3)
    maxX
        type patch;
        faces
            (2 6 5 1)
    minY
        type wall;
        faces
            (1 5 4 0)
    minZ
        type wall;
        faces
            (0 3 2 1)
    maxZ
        type wall;
        faces
            (4 5 6 7)
mergePatchPairs
after running "blockMesh" I ran "topoSet" with the following topoSetDict:
actions
    // Left
        name    left;
        type    cellSet;
        action    new;
        source    boxToCell;
        sourceInfo
            box (0 0 0) (0.5 1 1)
        name    left;
        type    cellZoneSet;
        action    new;
        source    setToCellZone;
        sourceInfo
            set left;
    // Right
        name    right;
        type    cellSet;
        action    new;
        source    boxToCell;
        sourceInfo
            box (0.5 0 0) (1 1 1)
        name    right;
        type    cellZoneSet;
        action    new;
        sourceInfo
            set right;
So actually I just want to divide it into two parts, "left" and "right". The border should be in the middle of the volume at "x = 0.5".
After doing so I get the two files "polyMesh/sets/left" and "right". Both containing 500 different numbers, I'm assuming that are the cellIds. Okay, so far so good.
But when I run "splitMeshRegions -cellZones -overwrite" I will receive the following output:
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:1
Writing region per cell file (for manual decomposition) to "/home/gp/OpenFOAM/gp-2.1.1/run/multiRegionElectrostatics/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/gp/OpenFOAM/gp-2.1.1/run/multiRegionElectrostatics/0/cellToRegion"
Region    Cells
0    1000
Region    Zone    Name
0    -1    domain0
Sizes of interfaces between regions:
Interface    Region    Region    Faces
Reading volScalarField phi
Reading volScalarField cellToRegion
Only one region. Doing nothing.
End
I am wondering—am I missing something? Is there a simple explanation why splitMeshRegions doesn't detect the two specified regions?
I am running on OF 2.1.1. if that matters.
Thank you so much for the time to read this thread and for your answer in advance.
Best regards
Georg
GPesch is offline   Reply With Quote
Old   November 13, 2013, 15:39
Jace
zhengzh5 is on a distinguished road
hey, not sure if that's causing trouble but your definition of right zone should be
sourceInfo
box (0.5 1 1) (1 1 1)
and not
sourceInfo
Originally Posted by GPesch View Post
convertToMeters 1;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 1)
    (1 0 1)
    (1 1 1)
    (0 1 1)
blocks
edges
boundary
    maxY
        type wall;
        faces
            (3 7 6 2)
    minX
        type patch;
        faces
            (0 4 7 3)
    maxX
        type patch;
        faces
            (2 6 5 1)
    minY
        type wall;
        faces
            (1 5 4 0)
    minZ
        type wall;
        faces
            (0 3 2 1)
    maxZ
        type wall;
        faces
            (4 5 6 7)
mergePatchPairs
actions
    // Left
        name    left;
        type    cellSet;
        action    new;
        source    boxToCell;
        sourceInfo
        name    left;
        type    cellZoneSet;
        action    new;
        sourceInfo
            set left;
    // Right
        name    right;
        type    cellSet;
        action    new;
        source    boxToCell;
        sourceInfo
        name    right;
        type    cellZoneSet;
        action    new;
        sourceInfo
            set right;
Create time
Number of regions:1
Region    Cells
0    1000
Region    Zone    Name
0    -1    domain0
End
Best regards
Georg
zhengzh5 is offline   Reply With Quote
Old   November 14, 2013, 05:20
sourceInfo
and not
sourceInfo
Are you sure? box(0.5 1 1) (1 1 1) is defining a flat area, not a box—or am I mistaking?
[OpenFOAM] Paraview 3.98.0 does not update list of mesh regions letzel ParaView 6 April 19, 2021 15:57
[snappyHexMesh] multiple regions Tobi OpenFOAM Meshing & Mesh Conversion 56 March 29, 2020 04:53
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
refinement causes composite regions, how to solve? Harry CFX 4 December 8, 2004 05:13
