OpenFoam Running in parallel
Old   November 4, 2013, 13:05
Default OpenFoam Running in parallel
Salam Hassan
Salam-H is on a distinguished road
Hi every one, I hope someone can help. I am trying to run openfoam in parallel. I have 8 processor in the decomposepar when I run it I get the following error massage , I would be grateful if someone tells how to fix it.
the shape I have is funnel. however when I use a cubic shape I dont get any error every thing goes well. I modified the dambreak case.
best regards,
Salam
Salam-H is offline   Reply With Quote
Old   November 7, 2013, 13:45
Nima Samkhaniani
nimasam is on a distinguished road
it seems your solution is diverging and it is not related to your parallel set up, could you run it in serial?
P { margin-bottom: 0.08in; } Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 1.2000578e-06
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
openfoam runing parallel
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 09:55
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running sunliming OpenFOAM Bugs 21 November 22, 2013 03:38
Running in parallel Djub OpenFOAM Running, Solving & CFD 3 January 24, 2013 16:01
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
OpenFOAM 14 stock version parallel bug msrinath80 OpenFOAM Bugs 2 May 30, 2007 14:47
