-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   mapFields with multi regions (http://www.cfd-online.com/Forums/openfoam-pre-processing/126041-mapfields-multi-regions.html)
Ahmed Khattab November 6, 2013 18:32
Dear All,
i want to use mapFields with multi Region target. i use openfoam2.1.0, which offers this option (-TargetRegion) for one region only.
can anyone help me?
samiam1000 November 8, 2013 03:57
I had the same problem and I solved using the option
-sourceRegion region_n -targetRegion region_n
as many times as my region were.
It works
Ahmed Khattab November 8, 2013 07:23
do you mean for example
mapFields -targetRegion heater -targetRegion solid -tergetRegion air
samiam1000 November 8, 2013 07:44
No, I meant:
-sourceRegion heater -targetRegion heater
and
-sourceRegion solid -targetRegion solid
and
-sourceRegion air -targetRegion air
Is that clear, now?
Ahmed Khattab November 8, 2013 12:14
Originally Posted by samiam1000 (Post 461176)
No, I meant:
and
and
Is that clear, now?
i tried it but it didn't work with me. beside, i have one region in my source and multiregions in my target.
thanks for your effort.
samiam1000 November 8, 2013 12:19
If you have one single region in the source and you want a multiregion in the target, I suggest you to create cellZones in the source, as well. Then you can map them, I think!
Mojtaba.a September 7, 2014 04:16
Originally Posted by Ahmed Khattab (Post 461223)
Dear Ahmed, have you been able to solve this problem?
I want to map source case with one region into target case with multiple regions and I have problem doing that. Did you find any solution !?
