Change P-rgh to Pfor interFoam
I am working on a multiphase flow. I have P value but in interfoam P_rgh is given. How to change P-rgh to P in the solver???
in your solver both variables exists. Can you describe your Problem in a other way? Do you want to set up "p" instead of "p_rgh"? Code:
p_rgh = p - rho*gh; |
Tobi, I am working on an external nozzle flow problem. In this case, the inlet pressure to the nozzle is know to me and the outlet is atmosphere.
Now in interFoam, we have p_rgh instead of P. Now If I am not wrong, P_rgh is the local dynamic pressure. SO how to set P in this case. If my inlet P is 4e6 what will be my p_rgh??? |
yes Tobi, I want to set P. Can you tell me how to do it????
As you can see in the code above the p-file is not read while starting the solver but will be automatically generated every time step you save.
For your Problem the easiest way would be the following: - calculate p_rgh at the inlet and set it to fixedValue so that you reach p As shown you can do this with: Code:
2. you know rho 3. you know g 4. you should know h |
