dynamicMesh case setup simpleton questions
Old   January 16, 2014, 15:57
Default dynamicMesh case setup simpleton questions
Debb
tellico is on a distinguished road
im trying to set up a dynamic mesh case for a ball free falling in a box. the geometry is simple but I'm confused as to how to specify the ball. is it a "cut out" of the box geometry, or simply internal "faces"?
if I understand correctly, the "pointMotionUx" files are were I would then specify the movement of the ball, but do I also need to specify the movement in the U file?
tellico is offline   Reply With Quote
Old   January 16, 2014, 17:13
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
If the ball itself doesn't need to be simulated (e.g. no heat transfer in the ball), you can cut it out of the domain and set the generated boundary as a moving wall.
You will need to change the mesh topology throughout the simulation as the ball falls. Depending on how you mesh your domain you can either use layerAdditionRemoval with something like the movingConeTopoFvMesh, or use fvMotionSolver dynamic mesh and remesh the domain when the mesh quality deteriorates.
mturcios777 is offline   Reply With Quote
Old   January 17, 2014, 12:41
Debb
Thanks for the tips. I got the simulation to run although I'm not sure where to account for the effect of gravity. Is there a tutorial that deals with free fall?
Duct case setup - Fan simulation nkjsimulating Main CFD Forum 0 October 10, 2013 04:15
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
Unsteady state case setup Christian FLUENT 2 February 16, 2003 17:11
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 09:50
