[PyFoam] pyFoamVtkSurface
Old   January 30, 2014, 06:00
Default pyFoamVtkSurface
Ehsan
Essy is on a distinguished road
Hi
I am using pyFoamSurfacePlot.py to create some animations. It works fine as long as I am importing files from my computer but when I want to use some files from SFTP there is a problem! it seems that it can not access SFTP. Do I need to install especial libs for this purpose?
I appreciate any Idea.
Thanks
Ehsan
Essy is offline   Reply With Quote
Old   January 30, 2014, 06:16
Assistant Moderator
Bernhard Gschaider
Originally Posted by Essy View Post
Hi
I am using pyFoamVtkSurface.py to create some animations. It works fine as long as I am importing files from my computer but when I want to use some files from SFTP there is a problem! it seems that it can not access SFTP. Do I need to install especial libs for this purpose?
Thanks
Ehsan
I'm responsible for a lot of crimes that start with pyFoam and end with .py but that one is new to me. And googling for "pyFoamVtkSurface.py" didn't get me anything relevant. Where have you got that from? (just curious, won't sue anyone for trademark. I Promise)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 30, 2014, 08:44
Ehsan
Thank you Bernhard for your quick reply. Sorry I made a mistake! As You might have guessed the correct name of the script is "pyFoamSurfacePlot.py". Is there any way to have this utility access cases which are on the SFTP?
Old   January 30, 2014, 10:03
Assistant Moderator
Bernhard Gschaider
First reaction was "maybe I wrote a utility of that name and forgot about it"
Anyway: no. There is no direct support for SFTP. And it wouldn't make much sense as in order to plot the files they would have to be loaded over the network (acually TWICE: once to look at them for minima and maxima and a second time for the actual plotting).
Anyway: what I'd suggest is "SSH over FUSE":
http://en.wikipedia.org/wiki/SSHFS
That looks like a regular filesystem (so pyFoamSurfacePlot.py can work with it)
Old   January 31, 2014, 01:30
Ehsan
Many thanks for your help Bernhard. It works fine with SSHFS!
pyfoam, pyfoamsurfaceplot.py
