Home > Forums > OpenFOAM Pre-Processing
Moving surface (with swak4Foam perhaps?)
Old   February 7, 2014, 15:08
Default Moving surface (with swak4Foam perhaps?)
Kostis
cosbergel is on a distinguished road
Hi guys,
Does anybody know if I can have a moving surface (maybe using swak). Something like :
planeAverage
type swakExpression;
valueType surface;
surfaceName surface;
surface {
type plane;
basePoint (0 $expression 0);
normalVector (0 1 0);
interpolate false;
verbose true;
expression "blabla";
accumulations (
average
Thank you
Kostis
cosbergel is offline   Reply With Quote
Old   February 10, 2014, 16:42
immortality's Avatar
Ehsan
immortality is on a distinguished road
what do you intend exactly? do you want to obtain averages on a moving wall? how it moves?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   February 11, 2014, 13:00
Kostis
Thank you for the answer.
I am simulating a falling droplet and I would like to define a moving surface inside my domain which will have fixed distance from the interface of the droplet in order to calculate the drag force by integrating the momentum flow rate across the particular plane.
Old   February 14, 2014, 12:18
Assistant Moderator
Bernhard Gschaider
Interface of the droplet (assuming you're using interFoam) you can get with a isoSurface sampled surface. Distance from that surface is a bit more tricky. There comes a plugin-library with swak that defines functions related to sampled surfaces. One of them generates a field that is the distance from a surface.
So one way to do this (if I understand your problem correctly) would be with a sequence of functionObjects:
- generate iso-surface sampled Surface
- generate a field with the distance from that surface (but only use the values where alpha>0)
- from that field generate another isoSampled-Surface
- do your evaluations on that
Have a look at Examples/other/angledDuctImplciit. I think that is where I test these plugin-functions
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 04:23
Moving Surface Pedro Romero FLUENT 0 March 30, 2007 12:09
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
