Home > Forums > OpenFOAM Pre-Processing
Boundary Condition for pressure and velocity
Old   May 3, 2014, 01:20
Default Boundary Condition for pressure and velocity
Mohammad Bahreini
mecman is on a distinguished road
Hi everybody
I have question about boundary condition setup in my test case. I am dealing with a case which is totally surrounded by walls all over the boundaries. I am using buoyant pressure and zero gradient boundary conditions for pressure equation. Furthermore, no-slip boundary condition is applied on the walls. Setting the case up in this manner, leads to an unexpected increase in the velocity of one corner which is the result of wrong pressure distribution at the same time. However, if I set zero pressure at one of the boundaries this problem does not occur.
I have also tested the exact same case with interFoam solver using buoyant pressure and zero gradient boundary conditions for pressure equation (Original OpenFOAM solver without any modification). In this case, everything is O.K.
I am guessing that the source terms in the pressure equation are responsible for this error. Would you please kindly provide your comments about this problem?
Best wishes
mecman is offline   Reply With Quote
Old   May 7, 2014, 16:51
Artur's Avatar
Artur is on a distinguished road
I'm afraid a bit more detail is required for anyone to be able to help you.
Please have a look at this thread in order to get an idea of what may be required:
Artur is offline   Reply With Quote
Thread Tools
Trackbacks are On
Pressure boundary condition for unsteady velocity inlet DanM OpenFOAM Running, Solving & CFD 6 July 5, 2015 09:21
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
Robin boundary condition for the velocity fumiya OpenFOAM 4 June 17, 2011 02:58
velocity boundary condition Logan Page OpenFOAM 0 November 19, 2010 18:59
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
