Free convection
Old   February 21, 2014, 10:37
Default Free convection
Michael Leck
Micha69822 is on a distinguished road
Hey guys,
I try to simulate a verticale plate in the atmosphere. For this case I create a box and on one side I add a small plate. Around I want to have everywhere atmosphere (air). The plate should have an temperature from 333 K and the atmosphere should have 293 K.
However I get always worst results. I think my boundarys are wrong.
Have somebody fixed this issue and can sent me a example case or tell me the right boundarys in the T, U, p_rgh and P file for my plate and the atmosphere?
regards
Michael
Micha69822 is offline   Reply With Quote
Old   March 6, 2014, 05:08
Default Please furnish more details
Sushanta Sahu
sengerandu is on a distinguished road
Can you please furnish more details like what is the element size, number, layers, etc?
sengerandu is offline   Reply With Quote
Old   March 6, 2014, 06:31
Michael Leck
Hello sengerandu,
thank you for your reply.
My first cell ist 0,014 mm thick and the gradient ist 20.
Now I've changed my case. I have a horizontal zylinder. In the vertical I used a symmetrPlane to reduce my mesh. Also I simulate 2D now.
T-File:
Is on atmosphere "inletOutlet" and on the wall ist "fixedValue".
U-File:
For atmosphere I use "pressureInletOutletVelocity" and for the wall I use "fixedValue".
P-File ist "calculated"
I think there ist a problem with the p_rgh file. Here I tried a lot of values:
fixedValue, fixedFluxPressure, zeroGradient, totalPressure for the wall and atmosphere.
And my flow pattern look like worse!
Best wishes
Michael
Old   March 10, 2014, 10:35
cristina is on a distinguished road
Micha69822,
¿did you get your case runnin? You are trying to simulate an open environment aren´t you? So am I, but I dont get any physical results....
It must be the boundary conditions...
Cristina
cristina is offline   Reply With Quote
Old   March 10, 2014, 13:35
Michael Leck
yes I did.
My failure was the p_rgh File. The bottom has to defined as "totalPressure" and the atmosphere around has to "inletOutlet". The other BC's the same as I described.
And now I get the right solutions!
Best regards
Michael
Old   March 11, 2014, 05:58
Hi Micha69822,
Which solver are you using? buoyantBoussinesqSimpleFoam? I am trying with SimpleFoam, but I do not find the right BC.
I have flow over a ground in atmospheric conditions.... very simple: inlet (constant wind velocity) outlet, sides and Sky and then the ground....
As you recommended, I am using totalPressure in the outet but I dont get good results...
Can you post your BC more detailed? I also attach you my case, maybe you can help me...
thanks!
Cristina
Old   March 11, 2014, 07:41
Michael Leck
Hi cristina,
I can't work with your files because I use OpenFOAM Version 2.3.0.
But I see in your blockMeshDict that you have defined all faces as wall. For atmosphere you need patch but there is a different in the Versions?!
Best regards
Michael
Old   March 11, 2014, 08:27
In effect, when I change the BC to patch it does not even run.... I dont know. Can you detail me your BC? So I can try to do the same?
thank!
Old   March 11, 2014, 10:07
Michael Leck
Hello cristina,
my settings in the attachment. I hope it help you?
I forgot to tell you my Sovler. I use the buoyantBoussinesqSimpleFoam and the buoyantSimpleFoam.
Best regards
Michael
Old   March 12, 2014, 02:20
Hi Micha,
¿your bottom is a wall? ¿like the ground?
Cristina
Old   March 12, 2014, 04:55
Michael Leck
no. I simulate a pipe an this surface is in my case the wall.
Best regards
Michael
atmosphere, natural convection
free convection Arun3012 FLUENT 0 February 25, 2013 00:45
Free convection ebrattr COMSOL 6 August 20, 2012 16:05
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 02:54
Free Convection in STAR-CD George Hampel Siemens 0 November 15, 2000 23:38
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
