Case setup with multiple heat generating bodies |
May 1, 2019, 12:24 |
Rep Power: 10 |
Let's say I have one domain of a rectangular prism. It contains a fluid and several solid volumes displacing the fluid at various locations. If I desire to specify a unique q''' (volumetric heat generation rate) for each solid volume, will I need a unique cellZone and set of thermophysicalProperties for each solid volume? Thanks for your time, |
May 2, 2019, 03:16 |
Yes, If you want to specify unique q for each volume, then you need unique cellZone and thermophysicalProperties for each solid volume. I am working CHT from some time having multiple bodies (in order of 100). I define heat generation for each body separately for unique heat source. There might be another possibility but I am not familiar with that and in my opinion for unique bodies you need unique cellzones. |
May 2, 2019, 08:32 |
#3 | |
Rep Power: 10 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
conjugate heat transfer case from two meshes | skuznet | OpenFOAM Pre-Processing | 0 | July 1, 2014 17:09 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
