February 23, 2014, 11:25 |
Need serious help please! --- Supersonic helium jet with sonicFoam
Guillaume Sahut
Rep Power: 12 |
Hi everyone,
This is my first post on this forum, I hope someone can help me. I want to simulate a supersonic helium jet coming from a nozzle and expanding into an helium atmosphere (helium jet in helium environment, so the Mach number is calculated with respect to sound velocity in helium). I want to do it with sonicFoam. I'm new to serious case study with OpenFoam: I've already used it but limited myself to basic properties like zeroGradient and fixedValue... For now, to simplify the case, my inlet is the exit of the nozzle, so I just want to simulate the jet which goes out of the nozzle, not what happens in the nozzle. My mesh is axisymmetric. This is what the domain looks like: The small white part at the bottom left is the inlet, the big one at the right is the outlet. The command ideasUnvToFoam worked well and checkMesh says "Mesh OK". constant/polyMesh/boundary : Code:
inlet { type patch; nFaces 4; startFace 10049; } outlet { type patch; nFaces 51; startFace 10053; } aboveInlet { type wall; nFaces 47; startFace 10104; } top { type wall; nFaces 100; startFace 10151; } front { type wedge; nFaces 5100; startFace 10251; } back { type wedge; nFaces 5100; startFace 15351; } constant/thermophysicalProperties : Code:
thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 4.0; } thermodynamics { Cp 5193.1; Hf 0; } transport { mu 2.146e-05; Pr 0.69738; } } 0/p : Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { front { type wedge; } back { type wedge; } top { type zeroGradient; } aboveInlet { type zeroGradient; } inlet { type fixedValue; value uniform 1013250; } outlet { type waveTransmissive; field p; phi phi; rho rho; psi thermo:psi; gamma 1.66; fieldInf 100.0; lInf 1; value uniform 101325; } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { front { type wedge; } back { type wedge; } top { type zeroGradient; } aboveInlet { type zeroGradient; } inlet { type fixedValue; value uniform 350; } outlet { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { front { type wedge; } back { type wedge; } top { type fixedValue; value uniform (0 0 0); } aboveInlet { type fixedValue; value uniform (0 0 0); } inlet { type pressureInletVelocity; phi phi; rho rho; value uniform (0 0 0); } outlet { type zeroGradient; } } I've been looking for the right boundary conditions for weeks. I've browsed the Doxygen documentation and found pressureInletVelocity and waveTransmissive which seem to be what I'm looking for... but here is what I obtain at t=6.9e-7s with a time step of dt=3e-9s: The maximum velocity in the X-direction should be along the X-axis, right? I think my boundary conditions are wrong... What's wrong with my files? Could someone help me, please? It's driving me crazy... Another question related to sonicFoam: when I try to visualize pressure or temperature in paraView on a calculation made by sonicFoam (this one, for instance), the values are always between 0 and 1, even if I fix them to other values! Could you tell me what happens? Thank you very much in advance. Last edited by Intrepid; February 25, 2014 at 13:03. |
February 25, 2014, 12:59 |
Guillaume Sahut
Rep Power: 12 |
Anyone? Please I really need help with OpenFoam! I know it's a classic case but I can't get it work... I can't find a complete tutorial... People are making videos of supersonic flows but never really say HOW they do it...
How would you do to simulate a supersonic flow coming from a nozzle, with sonicFoam or maybe rhoCentralFoam (I don't even know if there is a difference)? What would your boundary conditions be? Can you share your p, T and U files? Thank you very much to those who'll take the time to help... |
February 26, 2014, 03:15 |
I think you may need to change your static pressure on the inlet to a total pressure. Also it may just be some startup effects. Or maybe your mesh density is not sufficient. Hard to tell. About ParaView: probably you have to set to automatically scale to the entire data range. Usually you open ParaView, show some data, choose your favorite colorbar, tick automatically scale to data range, hit set as default and close ParaView. Next time it should scale to the entire range automatically. But the behavior has changed a bit from version to version. Regards, Tom |
February 26, 2014, 09:26 |
Guillaume Sahut
Rep Power: 12 |
Hi tomf, thank you for your reply!
I've tried totalPressure as mentionned here, like this in 0/p: Code:
inlet { type totalPressure; U U; phi phi; rho none; psi thermo:psi; gamma 1.66; p0 uniform 101325; } Here is my mesh: You think it could come from the fact that my cells are too big? For pressure and temperature visualization in paraView, it also comes from a BC since with pressureInletOutletVelocity, I guess I once had the correct values... |
February 26, 2014, 09:40 |
Maybe you can get some grading in the y-direction, so you have more cells near the edge of your nozzle. Than also run the simulation longer and see what happens.
In using the totalPressure BC, p0 should be your total pressure (I assume this should be 1013250 Pa, as you have in your code example for pressureInletVelocity). So: Code:
inlet { type totalPressure; U U; phi phi; rho none; psi thermo:psi; gamma 1.66; p0 uniform 1013250; } Tom |
December 24, 2018, 02:43 |
Abdelrazik Essam
Rep Power: 7 |
why did you assign fieldinf to be 100 in p0 ?
April 15, 2019, 02:49 |
shengjuan
Have you solved your problem? Can you show me your settings? Cause I changed lots of things but it didn't work. I wish you chould show me the complete settings if you don't mind,thanks a lot.
May 1, 2019, 22:04 |
Same Problem
sam zou
Hi, I am working on the same problem with air. I have tried many different settings but got the wrong results similar to yours as well. Did you happen to fix the problem? Please let me know.
boundary conditions, pressure, sonicfoam |
Jet in Supersonic Crossflow, controlling mass flow rate | ChrisA | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 18:20 |
C-D nozzle supersonic jet boundary | Gland | FLUENT | 4 | May 24, 2012 00:25 |
Liquid Jet into Supersonic Flow | Alex | CFX | 4 | June 20, 2007 10:56 |
Supersonic Jet Flows | Danny Tan | FLUENT | 0 | November 30, 2001 21:01 |
Turbulence model for supersonic jet | Danny Tandra | Main CFD Forum | 3 | August 24, 2001 04:10 |
