AirfoilCalculation Tutorial Error
Like Tree1Likes
  • 1 Post By afrotimy
Old   February 27, 2014, 21:43
Default AirfoilCalculation Tutorial Error
Francis
afrotimy is on a distinguished road
Hi FOAMERs,
I am trying to start up airfoil simulation in OpenFOAM with the airfoil calculation tutorial but having problem executing this command:
Procedure
"To save you for a lot of typing, an Octave-script NACA2STL.m has been made. Download the script into a directory of your choice and make
it executable.:
Terminal window
chmod +x NACA2STL.m
./NACA2STL.m
These commands will create a STL-file of a NACA0015 airfoil with a chord length of 1 meter. You might need to edit the first line in the script (#!/usr/bin/octave -qf) if your Octave-binary is located in another location than /usr/bin. Put the file in the airfoil_snappyHexMesh/constant/triSurface directory.
Error message
xx@ubuntu:~/OpenFOAM/xx-2.3.0/run/tutorials/incompressible/pimpleDyMFoam/airfoil$ chmod +x NACA2STL.m
chmod: cannot access `NACA2STL.m': No such file or directory
xx@ubuntu:~/OpenFOAM/xx-2.3.0/run/tutorials/incompressible/pimpleDyMFoam/airfoil$ ./NACA2STL.m
bash: ./NACA2STL.m: /usr/bin/octave: bad interpreter: No such file or directory
I have tried to place the NACA2STK.m file into the usr/bin but not permitted and can't fully still execute the command in any other directory. Can anyone help to throw more light on this procedure I think I am not getting a step right?
Many thanks.
afrotimy is offline   Reply With Quote
Old   February 27, 2014, 22:31
Francis
Hi FOAMers,
Problem resolved.
I was able to figure out that Octave is a tool for reading and writing binary codes and that it is not installed in my usr/bin directory.
I just installed Octave via the link:
http://blogs.bu.edu/mhirsch/2012/08/...-ubuntu-12-04/
Now, my airfoil.stl file has been successfully created with the directory it was saved in.
Cheers.
Clément_G likes this.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
