June 22, 2018, 08:18 |
simpleFoam solutions and relaxaiton factor
Eduardo Firvida
Rep Power: 15 |
Hi foamers!!
I have a question about relaxation factor and the accuracy of the solution. I'm running a 2D flow over a square cylinder case, for differents Reynolds numbers. The things Is that I have tested the same case for different configurations, and relaxations factor, and the result in some cases are very far from each other, so I don't know how to set the correct one. the attachment shows a different plots derived from my simulations to clarify my question |
June 23, 2018, 04:49 |
anonymous
Rep Power: 14 |
Hi!
Have you reached the convergence in all cases? And what is simulation time? simpleFoam is a steady-state solver, you have no time there. The time in simpleFoam is just like an iteration step towards your solution, it's not a real time. With smaller relaxation factors you will need more iterations since if you should step 1 towards your solution, you step only 0.8 (with 0.8 relax factor. It's not that simple but something like that.) With different schemes you can get a bit different results especially in physically complex cases, but i think this is too much. What was the convergence criteria in the cases? You also monitored the drag coefficient, or just stopped after the residuals became "small"? |
June 24, 2018, 16:42 |
#3 | |
Eduardo Firvida
Rep Power: 15 |
and the drag coefficien lice this: and my fvSolution file is: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; smoother DICGaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 500; nPreSweeps 1; nPostSweeps 2; nFinestSweeps 2; agglomerator faceAreaPair; mergeLevels 2; tolerance 1e-012; relTol 0; } pFinal { $p; tolerance 1e-06; relTol 0; } U { type coupled; solver PBiCCCG; preconditioner DILU; tolerance (1e-05 1e-05 1e-05); relTol (0 0 0); } "(k|epsilon|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 1; residualControl { p 1e-5; U 1e-5; "(k|epsilon|omega)" 1e-5; } } relaxationFactors { fields { p <variable>; } equations { U <variable>; ".*" <variable>; } } // ************************************************************************* // |
