SimpleFoam results as initial condition to rhoSimpleFoam
Old   November 21, 2013, 18:07
Default SimpleFoam results as initial condition to rhoSimpleFoam
Marcelo
marcelorl is on a distinguished road
Hi All,
Is it possible to use a incompressible results as a initial condition to a compressible case? (I know that there is difference in the pressure dimension and there are different fields for each case).
I am currently using rhoSimpleFoam to solve the problem, but I am having a lot of convergence problems. So, I would like to know if it is possible to run the problem with simpleFoam and use the fields as initial condition to rhoSimpleFoam.
Thank you for the help.
Regards,
Marcelo
marcelorl is offline   Reply With Quote
Old   November 21, 2013, 20:05
doctorV is on a distinguished road
I had a lot of convergence troubles with rhoSimpleFoam and rhoSimplecFoam. What are you simulating? Is it an airfoil or an internal flow? Anyway if you don't set right boundary conditions solver will crash for sure.
doctorV is offline   Reply With Quote
Old   November 22, 2013, 12:45
Marcelo
I am working on a labyrinth seal. My boundary conditions are pressure defined in the inlet and outlet. As I know it is very unstable boundary condition, I put zero gradiente for pressure in the inlet and changed the velocity until the pressure goes to 10 MPa.Outlet is pressure (8Mpa) defined and zero gradient for velocity. the velocity residual is ok, but the pressure is oscilating and i have tried everything that i could without success.
Do you know anything that I can try?
Thank you very much for the help.
Old   November 22, 2013, 13:17
Could you post some pictures of your mesh? The solution to your trouble is in a Lilek-Peric-Demirdzic paper of 1993: it's about SIMPLE algorithm corrected for compressible flows. It shows boundary conditions of ducted flows for subsonic, transonic and supersonic cases. If you don't use right boundary conditions, solver run will explode for sure: remember the nature of problems (elliptic, hyperbolic, parabolic). I was able to run those literature cases successfully, and it required few minutes/seconds, but after 15 day I still have troubles with external flows (airfoils and wings).
Old   November 25, 2013, 09:24
Bernhard Linseisen
Linse is on a distinguished road
Dear Marcelo,
fundamentally, it should be possible to use the results from simpleFoam also with rhoSimpleFoam.
BUT: Be aware that the solvers have different dimensions for the pressure field!
In general, in OF the incompressible solvers use p/rho, while the compressible solvers use p . Therefore you will have to think how to recalculate the pressure field for proper use within the compressible solver!
(Unfortunately I do not know about any tools or standard algorithms which can help you with that...)
Linse is offline   Reply With Quote
Old   March 7, 2014, 10:08
Samuele Z
samiam1000 is on a distinguished road
I am trying to use rhoSimpleFoam in order to simulate the flow over an airfoil.
I have many problem with convergence.
Have you ever done something like this?
Could you share a case, please?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
pisoFoam - unstable pressure residual Industrial_CFD OpenFOAM Running, Solving & CFD 21 February 24, 2013 15:39
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
