Bubble rising, specification of the interface
Like Tree1Likes
  • 1 Post By ybapat
Old   March 5, 2014, 20:29
Default Bubble rising, specification of the interface
Prosper is on a distinguished road
Hi All,
I just started using OpenFoam and now I'm trying to do a bubble rising problem. Since I'm new, I could have make some seriously stupid mistakes. So I'll be grateful if you can guide me to the right direction.
So I used interDyMFoam. (because I may need to add a solid object later to see the deformation of the bubble.) I think the right place to specify the initial shape of the bubble is in system/setFieldsDict, by defining a 'box' in boxToCell.
My first question is, is it possible to give a circular shape to the interface? What I'm doing now is
box (0.4 0.4 -1.0) (0.5 0.5 1.0)
which gives me a rectangle initial shape.
Second question, if I want to add a fixed(or maybe free falling) solid object to the fluid domain, so that when the bubble rises it deforms due to the presence of the solid, where should I specify the position and shape of the object. Should I add that in the boundary conditions? How about mesh refinement? I am using 'dynamicMeshDict', does it also work with presence of solid object?
Thanks for any piece of advice!
Best,
Prosper is offline   Reply With Quote
Old   March 6, 2014, 03:56
Yogesh Bapat
ybapat is on a distinguished road
Hello ,
You can use sphereToCell to patch bubble. Also for fixed solid wall you can keep it as wall inside the domain.
-Yogesh
Prosper likes this.
ybapat is offline   Reply With Quote
Old   March 6, 2014, 11:38
Yogesh,
Thanks for your reply!
I am using cylinderToCell in my 2D case and it seems to be working. I'm sure I'll need sphereToCell in a 3D case.
So if I have a fixed solid wall, do I need to manually divide the single domain into hexagons? Do I need to treat the fixed solid as a hole in the domain? What if I have a solid with complicated shapes like a star? Can I just insert some solid into the domain instead of treating it as a hole?
Best,
Originally Posted by ybapat View Post
Hello ,
-Yogesh
Old   March 11, 2014, 11:05
Default From Salome Preprocessor to OpenFoam
Anil Kunwar
Annier is an unknown quantity at this point
How can we draw a geometry in Salome and export it to OpenFOAM?
Yours
Anil Kunwar
Annier is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
