Pushing a Sphere through a tube
Old   July 14, 2016, 11:45
Default Pushing a Sphere through a tube
Andrew Lindsay
andrewlindsay is on a distinguished road
Hello, I am trying to simulate blowing a sphere through a tube.
I am new to CFD and am looking for how to set up a model that would simulate this case.
Starting easily, I want to be able to just show a sphere with mass "m" and friction "mu" being pushed through a pipe.
Eventually I want to be able to model a vertical pipe with a constant air flow in at the bottom, pushing out water above the sphere to see at what point the sphere is just pushed out under the back pressure of the gas behind, as well as look at the velocity that the sphere exits the tube.
Any assistance in pointing to a similar example or tutorial of how I used OPEN Foam and Salome to do this modelling would be greatly appreciated.
andrewlindsay is offline   Reply With Quote
double tube heat exchanger mehyan CFX 4 December 8, 2015 16:44
[OpenFOAM] Tube filter in Paraview werweisswas ParaView 0 December 10, 2012 06:18
[ICEM] meshing a sphere - large deviation from perfect sphere murx ANSYS Meshing & Geometry 25 August 15, 2012 12:37
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
