How to define the geometry of an inlet?
Old   March 15, 2014, 20:08
Default How to define the geometry of an inlet?
P
FOAM1234 is on a distinguished road
Hi all,
I am trying to simulate flow through that passes through a sluice gate and into a flume. I have been trying to represent the flow from the sluice gate as an inlet patch that is part of a face while a wall composes the rest of that face. In doing so I get the following error:
FOAM FATAL ERROR:
face 0 in patch 0 does not have neighbour cell face: 4(0 8 9 1)
Here is the rest of my geometry:
vertices
(   //Domain
    (0 0 0)         //0
    (0 0 0.31)      //1
    (20 0 0.31)     //2
    (20 0 0)        //3
    (0 0.45 0)      //4
    (0 0.45 0.31)   //5
    (20 0.45 0.31)  //6
    (20 0.45 0)     //7
    //Inlet
    (0 0.02551 0)   //8
    (0 0.02551 0.31)//9
blocks
    hex (0 1 2 3 4 5 6 7) (25  25 15) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 8 9 1)
    walls
        type wall;
        faces
            (0 3 7 4) //sidewall
            (1 2 6 5) //sidewall
            (0 1 2 3) //floor of channel
            (8 4 5 9) //above inlet
    outlet
        type patch;
        faces
            (2 6 7 3)
    atmosphere
        type patch;
        faces
            (0 3 7 4)
            (8 4 5 9)
            (1 5 6 2)
            (1 3 2 0)
I understand why I am getting this error, but now I'm wondering how can I represent the flow from the sluice gate so that the flow depth from the inlet is constant?
FOAM1234 is offline   Reply With Quote
Old   March 17, 2014, 03:20
pingat is on a distinguished road
i think the problem is, that you wanna build up an internal face and not a boundary.
maybe you could have a look at the createbaffles tool?
pingat is offline   Reply With Quote
blockmeshdict block mesh, flumes, inlet and outlet
How to define a mass source at a velocity inlet ? cfdiscool FLUENT 4 June 26, 2014 03:00
define BCs at inlet and outlet for natural ventilation simulation jjz2013 Main CFD Forum 0 January 29, 2013 15:50
How to define constant value at inlet boundaries? moienmojabi Main CFD Forum 0 February 12, 2011 11:34
Which software to define the geometry ? nub74 ANSYS 0 May 25, 2010 11:58
F-16 inlet geometry Imran Main CFD Forum 2 May 16, 2007 08:42
