Different Transport Properties for Different CellZones
Old   April 3, 2014, 11:03
Default Different Transport Properties for Different CellZones
Yesaswi
yesaswi92 is on a distinguished road
I am trying to solve for a thermal flow with a porous plug. So there will be two cellZones in the mesh
- Fluid
- Porous Domain
The momentum equations for both the domains are different. porousSimpleFoam uses a subroutine to modify the governing equation in the porous zone. So there is no issue for flow solution.
Now to extend the same solver for thermal flow, I added the energy equation. For porous domain, the energy equation is same as it is for fluid domain. Only the transport properties will be different (In porous domain the thermal diffusivity is a volume averaged diffusivity of both the porous material and the fluid).
So I need to give two separate thermal diffusivity values for these two cellZones in the transportProperties file. Can anyone help me in implementing this?
Thank You
Yesaswi
{PS: In multiphase flows, we define the properties of two phases separately. Can I do that for the two cellzones separately?}
yesaswi92 is offline   Reply With Quote
Old   July 11, 2015, 01:33
Post Different transport properties to different cell zones
AJAY BHANDARI
AJAY BHANDARI is on a distinguished road
I have the same problem. I am simulating flow through a body tissue which is considered as a porous media. i have a rectangular mesh in which there a two concentric circles.all these three parts are different . they have same porosity but there transport properties are different. I have to assign different transport properties to all these parts. How can i implement this??? How can i assign different transport properties to different zones????? Do i have to code for this??? Plz suggest. Any kind of help will be appreciated....
AJAY BHANDARI is offline   Reply With Quote
Old   June 29, 2016, 12:33
catelyn is on a distinguished road
Hello!
Did you solve the problem?
I think I've a similar problem in defining a gravity field that depends on zones.
Could you help me?
catelyn is offline   Reply With Quote
Old   June 30, 2016, 01:16
Post
AJAY BHANDARI
Hi Catelyn,
Yes you can do it by making a setFieldDict file.
There you assign the properties to different zones. There are lot of zone geometries available like cylinderTo cell, Box To cell.
You can select it according to your choice and then assign properties.
After doing that type setFields on terminal.
I hope this helps..
Best
Ajay
Old   June 30, 2016, 04:55
Hi Ajay,
thank you for the reply.
I thought that setFields worked with "variables" (pressure, velocity) of the fields to be specified as initial conditions. Typing "setFields", in fact, the files contained in 0 folder change according to the instructions in setFieldsDict.
What I need is to diversify the properties (defined in constant) depending on the position.
Catelyn
Old   February 15, 2017, 06:50
Alejandro
ancolli is on a distinguished road
Originally Posted by catelyn View Post
Hi Ajay,
Catelyn
Did u manage to solve your problem? Can u explain to me?
ancolli is offline   Reply With Quote
Old   March 20, 2019, 08:40
ALOK KUMAR
alok1463 is on a distinguished road
Hi catelyn,
Did you find any way to solve your problem? I am facing similar problem.
alok1463 is offline   Reply With Quote
Old   March 20, 2019, 09:04
Alejandro
You should create a new field with your variable property and locate it in the 0 directory. It has no sense to have a "constant" (variable) transport property.
energy equation, porous flow, poroussimplefoam, thermal flow, transportproperties
Polynomial density and transport properties in buoyantBoussinesqSimpleFoam pedera OpenFOAM Running, Solving & CFD 29 November 16, 2016 02:33
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
Transport and Thermodynamic Properties in cavitatingFoam sfigato OpenFOAM Pre-Processing 0 January 7, 2013 10:59
ReactingFoam Laminar flame simulation transport properties gbansal OpenFOAM Running, Solving & CFD 3 November 23, 2012 16:03
Transport properties with PPDF combustion Erik Siemens 0 February 18, 2009 05:18
