April 13, 2014, 03:34 |
checkMesh error
S. Javad Saharkhiz
Rep Power: 12 |
hi all dear CFD users
i have a problem when i want to run may case.when i want to check my mesh it give me this error : Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/jvd/Desktop/MyCaseCopy/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting how i can fix this error.i don't understand this error. and what is "regIOobject" function & what mean when it say that it has problem at "line 0 !" ?? where in line 0 ? thanks |
April 13, 2014, 03:47 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings jvd.mechanic,
Apparently your case folder is named "My Case Copy" and unfortunately OpenFOAM is allergic to spaces in folder/file names. If you rename the folder to "My_Case_Copy" or "MyCaseCopy", it should work just fine. edit: for a more detailed answer, check the section Why do I get the error message "fileName::stripInvalid() called for invalid"? in the FAQ: http://openfoamwiki.net/index.php/FA..._invalid.22.3F Best regards, Bruno Last edited by wyldckat; April 13, 2014 at 03:50. Reason: see "edit:" |
April 13, 2014, 03:56 |
S. Javad Saharkhiz
Rep Power: 12 |
thanks for your answer
i know that OpenFoam has allergy with space and my folder name is MyCaseCopy and thank u for the address that u gave me |
April 13, 2014, 04:20 |
#4 | |
Bruno Santos
Rep Power: 128 |
Oh, I read your first post waaaaaay too fast . Let's see...
The "line 0" message is because the reader stopped at line 0 - it was ready to start reading, and then tried to open the file - but then it didn't find the file in question. Specifically, the file "system/controlDict" does not exist inside the folder "/home/jvd/Desktop/MyCaseCopy/". One of the reasons could have been because the folder was named "My Case Copy", but that should have given an error as the one explained in the FAQ. |
April 16, 2014, 02:33 |
S. Javad Saharkhiz
Rep Power: 12 |
thank u for your answer
my internet had problem and today i was able to read your message i'm going to run ubuntu and check files and i want to rename that :-) thanks a lot |
Display Modes | |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
