Home > Forums > OpenFOAM Pre-Processing
buoyantBoussinesqPimple p_rgh BOUNDARY CONDITIONS
Old   May 7, 2014, 04:23
Post buoyantBoussinesqPimple p_rgh BOUNDARY CONDITIONS
dell-ocqa aronne
aronne030389 is on a distinguished road
Hi everybody
i'm trying to set a simple simulation with buoyantBuossinesqPimpleFoam, but i have a problem with the BC, especially with p_rgh and p. As far as i have understood for the p i have to set calculated since it is obtained as p=p_rgh+rhok*gh . The case is the following : a rectangular 2D column domain vertically oriented,with later impermeable walls, filled by water a T1 temperature. From below i inject at a constant rate water at a greater temperature T2.
Now for the BC at the bottom i will set
U-> fixedValue
T-> fixedValue
p->calcualted
p_rgh-> ?? which is better?? zeroGradient is it possible or not for this variable??
at the Top
U-> zeroGradient
T->zeroGradient
p->calculated
p_rgh-> ?? which is better?? fixedValue uniform=0 since it is in atmosphere?? is it possible??
it is convenient to set the z coordinate at the top of my domain so i get p_rgh=p+0 ?? and setting p_rgh=0 as BC i will not have additional problems??
at the lateral wall i set
U-> zeroGradient
T->zeroGradient
p->calculated
p_rgh-> zeroGradient it is ok??
Another question is about the meaning of the last step in the PIMPLE algorithm
p = p_rgh + rhok*gh;
if (p_rgh.needReference())
p += dimensionedScalar
"p",
p.dimensions(),
pRefValue - getRefCellValue(p, pRefCell)
p_rgh = p - rhok*gh;
where i specify the needReference() option?? and also the pRefValue and pRefCell?? I have to specify them or not??
Thanks so much to everybody!!
aronne030389 is offline   Reply With Quote
Old   May 20, 2014, 08:24
Joachim Herb
jherb is on a distinguished road
pRefValue and pRefCell can be set in fvSolution:
http://www.openfoam.org/docs/user/fvSolution.php
jherb is offline   Reply With Quote
Thread Tools
Trackbacks are On
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
boundary conditions and mesh exporting vaina74 Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 May 27, 2010 09:38
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
