Setting up an initial velocity field for scalarTransportFoam
Old   May 10, 2014, 08:31
Default Setting up an initial velocity field for scalarTransportFoam
Marco Langiu
mala01 is on a distinguished road
Hello everyone,
I am new to OpenFOAM and therefore have some trouble getting a start on it, since I cannot find tutorials on what I'm looking for.
My aim is to simulate the mass transfer of oxygen in a falling flat film of water. To do this I decided to use the scalarTransportFoam solver which looked promising after I did the tutorial for the pitzDaily case.
However, I cannot find any documentation of how to set up the required velocity field without punching in the desired values for each cell by hand.
I've attempted to create a steady field by running a simulation using the interFoam solver, but the solving process failed due to numerical reasons I don't understand.
For a start I want to simulate my case in 2D with a steady velocity profile which should look like this: u(y) = g*h^2/nu*(y/h-.5*(y/h)^2)
Where h=10mm is the height of the film, which for now is assumed to be constant in the x (=flow) -direction.
My geometry is a simple, one block mesh of 50x10x1 mm with (100 10 1) cells.
Is there any simple way to implement this?
Do you have literature/tutorial suggestions?
I don't mean to bother you with these fundamental problems, but I searched for two days now and couldn't find anything that brought me any further.
Thank you for your help!
mala01 is offline   Reply With Quote
Old   May 11, 2014, 11:35
CTR
Charles
CTR is on a distinguished road
Hi Marco,
I think that you might want to research codedFixedValue boundary condition. It should allow you to define the velocity profile. Sorry I can't give you a detail answer, I am pretty new to OpenFOAM as well.
Charles
CTR is offline   Reply With Quote
Old   May 11, 2014, 12:10
Marco Langiu
Hey Charles,
thanks for that hint! I'll look into this as soon as I can.
generate, how to, initialize, set up, velocity field
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
