rammstan |
June 10, 2014 06:26 |
--> FOAM FATAL IO ERROR: keyword adjoint is undefined in dictionary
Hello, it's my first simulating with OpenFoam. I m trying to run this tutorial with linux CAE 2013 (12.04), and OpenFoam 2.1.1 terminal.
When i tun decomposePar, i get this output error:
Number of processor faces = 3271
Max number of cells = 15912 (128.354% above average 6968.12)
Max number of processor patches = 6 (26.3158% above average 4.75)
Max number of faces between processors = 1624 (98.5937% above average 817.75)
Time = 0
keyword adjoint is undefined in dictionary "/home/jean-louis/Documents/OpenFoam/casting_OF_2.3/0/p_rgh::boundaryField::wall"
file: /home/jean-louis/Documents/OpenFoam/casting_OF_2.3/0/p_rgh::boundaryField::wall from line 25 to line 26.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
I don't find any "adjoint" in p_rgh file :
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type fixedFluxPressure;
value uniform 0;
inlet
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
// lowerWall
// type fixedFluxPressure;
// value uniform 0;
outlet
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
// defaultFaces
// type empty;
Someone has an idea from where is the problem?
Thank you
