mapFields for 3D
Hey,
I am trying to use mapFields on a cylindrical capillary mesh to transfer fields from a coarse mesh to a finer mesh. My solver is interFoam. mapFields runs to completion when I just use the command mapFields with an empty mapFieldsDict file but when I start the solver I get the following error Code:
--> FOAM FATAL ERROR: When I run mapFields with the -consistent option as the geometry is the same I get the following error Code:
--> FOAM FATAL ERROR: Please help me out here. Thank you very much in advance. |
hello,
Seems that there is some bug with mapFields in OF 2.3 (mapFields has been rewriten in this version). Don't be lazy like me, and try to make a bug report on the tracker. Anyway, actually i am using mapField from OF 2.2, and all other tools/solver with 2.3. regards, olivier |
Hey Olivier,
Thank you very much for the reply. I had no idea there was a bug. It works fine with 2.2. Saved a ton of time for me. And yes I will try to make a bug report soon when I get the time. Thanks again :) Best, Praveen |
mapField from 2.2 on Ubuntu 14.04?
Hi guys,
Did you already try this option along with Ubuntu 14? I'm not able to solve with the dependencies issues when trying to compile 2.2 on latest UBUNTU LTS. If any idea, you're welcome! Tristan |
