[swak4Foam] groovyBC for defining heat influx at the boundary |
August 25, 2014, 01:06 |
Delstat
Rep Power: 13 |
Hi ,
I am using laplacianfoam for a heat-block case. I have gone thru the discussion - "Mixed BC - heat transfer - laplacianFoam" http://www.cfd-online.com/Forums/ope...acianfoam.html. From the forum discussions - "externalWallHeatFluxTemperature" and "groovyBC" were pointed out. I am interested to apply heat influx at the boundary wall.Please find the attached snapshot for more info. How to apply "groovyBC" for defining heat influx at the boundary in a heat-block? Thank you, Pradeep |
August 25, 2014, 17:38 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 25, 2014, 22:33 |
Delstat
Rep Power: 13 |
Thank you very much Bernhard
August 26, 2014, 00:02 |
Delstat
Rep Power: 13 |
Dear Bernhard,
For a case, flux is ------------>>>> q = -(k) * (dT/dx) (dT/dx) = - q /k We have : "q" is the heat flux : q = 10 (W/m2), "k" is the thermal Conductivity of the material : k = 200 (W/mK) HTML Code:
Outwall { type groovyBC; value uniform 293; gradientExpression “(-q)/k"; fractionExpression "0"; variables “q=10;k=200"; } Thank you! |
August 26, 2014, 08:12 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I usually limit myself to answers about the technical aspects of swak4Foam. Physics is your own responsibility
August 26, 2014, 19:54 |
Delstat
Rep Power: 13 |
Thank you very much. It worked!
November 13, 2014, 22:34 |
Chris Ostrom
Rep Power: 11 |
would it be possible to use a 'q' file that is the output from a different solver instead of defining one constant value for q on the boundary?
November 14, 2014, 05:01 |
#8 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I've explained it a number of times in different places: it is not THAT easy to do it in a general way (fileformats, different discretizations, error handling, parallel etc)
November 14, 2014, 05:52 |
#9 |
Chris Ostrom
Rep Power: 11 |
I apologize for asking a question that has been answered elsewhere, but...
I have a qMean file resulting from a dsmcFoam run, and I would like to use the heat fluxes from that as a boundary condition for a laplacianFoam runcase. is this currently possible in openFOAM 2.3.x without editing the *.h, *.c files? |
November 14, 2014, 07:16 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Depending on that timeVaryingMappedFixedValue might be able to help you
January 14, 2019, 06:38 |
#11 | |
Jianrui Zeng
Rep Power: 7 |
January 15, 2019, 05:47 |
#12 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
There are boundary conditions that implement constant heat-flux in OpenFOAM. If your heat-flux has no spatial or temporal distribution then I'd recommend using these. If you want to/have to use groovyBC the heat conductivity of the fluid is sufficient information to calculate the temperature gradient
January 15, 2019, 21:55 |
#13 | |
Jianrui Zeng
Rep Power: 7 |
I think I know the thermo conductivity of fluid in my case but I am using tabular method to get these thermopropertities. So kappa is changing with T and P and read from tabulated table. And I am using externalWallHeatFluxTemperature BC to give the constant heat flux. But I am not sure if kappaMethod : fluidThermo is suitable for my case. I use wallHeatFlux to check the heat flux after simulation. The result is far diffrernt from the setting one. But when I use #include wallHeatFlux to check heat flux during running, it give other heat flux values which are closer to the setting one in BC. So I am confused about the different behaviors of the utility. I just use it in different moments and it gives me different values. Any hint is highly appreciated. |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
