Simulating diffusion flames with fireFoam
Old   February 8, 2013, 09:38
Default Simulating diffusion flames with fireFoam
Bobby
babakflame is on a distinguished road
Dear Buddies
Hi
I want to simulate a diffusion flame with fireFoam. Does any body has any tutorial about this issue?
I would be very pleased if an experienced buddy help me on this object.
Thanks
bobi
babakflame is offline   Reply With Quote
Old   February 9, 2013, 03:25
Default more information from my work
Bobby
Dear Buddies
Hi
I have simulated diffusion flames with reactingFoam earlier. However now I want to simulate them with firefoams using FSD combustion model. I have looked into firefoam tutorials about poolfires. when I start my simulation, I got this error message:
Create time
Create mesh for time = 0.0522381
Reading g
Creating combustion model
Selecting combustion model FSD<psiCombustionModel,gasThermoPhysics>
Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysic s>>
Selecting chemistryReader foamChemistryReader
terminate called after throwing an instance of 'std::bad_cast'
what(): std::bad_cast
Aborted
I even deleted the chemistry properties file, made the chemistry solver off,modified the reactions file and the combustion model, Nevertheless I still get this error. I would be very please if an experienced fireFoam man help me.
Regards
Bobi
Old   April 3, 2013, 04:35
Matze7 is on a distinguished road
Hi Bobi,
the combustion models have changed in OpenFoam 2.2.0. I don't know why, but some of the combustion models, which worked fine on 2.1.1, don't work on 2.2.0.
you can try to replace
with
combustion model FSD<psiThermoCombustion,gasThermoPhysic>
Regards
Matze7 is offline   Reply With Quote
Old   April 4, 2013, 03:49
Bobby
Originally Posted by Matze7 View Post
Hi Bobi,
with
Regards
Hi Matze
Thanks for ur reply. now, I have a question about firefoam in 2.2.x. Does supprot multistep combustion?
As u know in 2.1.x firefoam only had singlestep combustion.
Regards
Bobi
Old   April 5, 2013, 06:11
Hey Bobi,
I've no idea if fireFoam can handle that, sorry. I'm new at simulating with fireFoam and so my experience with it is quite little. I'm still struggling to get my own simulation running .
Regards.
Old   April 13, 2013, 06:03
Bobby
Hi matze
I I have a doubt about 0 folder. In this folder we have to create distinct folder for any reactant. however, I want to know the value for each specie in boundary field is in mole or mass fraction?
Old   April 17, 2013, 07:41
Hi Bobi,
in my oppinion just mole fraction makes sense.
Old   May 20, 2013, 06:42
Bobby
Dear Buddies
Hi
I have simulated a cold flow with fireFoam. However, when I tried to ignite combustion by increasing the whole computational domain temperature to 1600 K and then injecting the reactants; I do not have the combustion yet.I think I have set out the chemistry, combustion and reaction files, correctly (according to its tutorials in openFoam). Would somebody PLZ help me on this? I can put any of my files that is needed for investigating my case. However, I should mention that I am trying to simulate one of Sandia flames with fireFoam and with FSD (Flame Surface Density) combustion model.
Old   May 22, 2013, 07:20
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
is your Diffusion flame laminar or turbulent?
Maybe you can use the flamelet-model tool (adverticement)
But I think bobi could give you a more accurate answer which solver you should use (:
PS: for turbulent flames it s possible to use the flamelet-model 2.2.x from my Homepage and for laminar flows, alberto cuoci build a new solver.
Tobi
Tobi is offline   Reply With Quote
Old   May 22, 2013, 07:38
Bobby
Hi Tobi
I am trying to simulate DLR flame (Sandia CH4-H2-N2) with fireFoam (FSD combustion model) which is a single-step flamelet/progress variable combustion model with LES.
Ofcourse I would be so much happy to link the flow solver of fireFoam (LES) with your flamelet code ; However I do not know that how can I link these together
can you hint me on this issue?
Regards
Bobi
Old   May 22, 2013, 08:20
Tobi's Avatar
Tobias Holzmann
Hi bobi,
you are still working on flamelet-model RAS reprogramming to LES?
Well as in the libOpenSmoke thread I am not familiar with LES modelling and there for I can not give you a advice or any hints to Combine both.
*sorry*
Do you have to simulate with LES ? RANS flamelet model and DLR flames are working very good.
Old   May 22, 2013, 10:10
Bobby
Hi Tobi
Unfortunately, As part of my thesis I should combine LES with steady flamelet.
I have succeeded this job in two different route.
First, I am trying fireFoam; Although with some progress there is still problem in igniting combustion.
Second, I am trying your code. At first I was thinking that I should change the simple algorithm to pimple plus changing the stoichiometric chi update formulation + turbulence model. After contacting Dr. Cuoci, I figured out That I just need to change the stoichiometric chi update formula plus changing turbulence model.
I am trying both route, and I hope to become successful
Regards
Bobi
Old   May 23, 2013, 07:11
Tobi's Avatar
Tobias Holzmann
Wow - Alberto answered you
Hmmm so you are sucessful in the LES with Albertos flamelet libraries ?
Old   May 23, 2013, 07:34
Bobby
Next Week; I will try again to build LES-Flamelet code
I will tell you the result of the code (compiled or not). I hope to succeed ; cause in the last try my problem was with pimple algorithm
Regards
Bobi
Old   August 27, 2013, 11:01
Default Janaf Thermo crash
  #15
TBO
TBO is on a distinguished road
All,
As proposed by Bobi on the libOpenSmokeForum I am trying to use fireFoam to model the turbulent mixing of methane jets in a swirling air flow (without combustion involved). However I get an error in a simplified model and I don't know what causes this error. The error is the following:
--> FOAM Warning :
From function janafThermo<EquationOfState>::limit(const scalar T) const
in file /home/.../OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -4667.51
It starts with some small deviations from the required temperature range but then the deviation starts to grow and finally the model crashes. I use the following boundary conditions:
internalField uniform 500;
boundaryField
outlet
type zeroGradient;
burnerwall
type zeroGradient;
inletair
type fixedValue;
value uniform 500;
inletfuel
type fixedValue;
value uniform 500;
So using this I assume that temperature field normally should be around 500 K and stay around this temperature (since combustion is off). Does anybody know what to do with this?
Thank you
TBO is offline   Reply With Quote
Old   August 28, 2013, 03:02
Bobby
Hi TBO
I hope to provide helpful suggestions for you.
1) first probability is your CFL number. Its maximum must not exceed about 0.4
2) check your grid quality. Sometimes grid quality at downstream causes this error.
3) Check your maximum DeltaT. It must not exceed 2e-06
4) your boundary conditions does not have impact on this error.Although I suggest to try another condition for burner wall(no slip condition)
Regards
Bobi
Old   September 10, 2013, 03:40
TBO
Thank you for your answer Bobi, I implemented the changes that you proposed. However the problem now is that DeltaT gets very small (1e-12), the result is that the calculation will take extremely long (actually impossibly long, it run for a couple of days on 12 processors and I reached time 0.0001, while I need to go to time 0.3 for a complete throughflow of my domain). This is already the case for a very simplified mesh of 60000 cells, I put a lot of effort in optimizing the mesh, for computional effort I already moved to a cyclic mesh.
How can I speed up the calculation and increase the timestep. In the end, I'm not interested in the transient behaviour but only in the steady state result. I am using fireFoam in OF 2.1.1 without chemistry, to model the mixing of a methane jet in air.
Regards,
Old   September 13, 2013, 11:32
Bobby
Hi TBO
Sorry for late answering, I was a bit busy last days.
My best suggestion for your case is this:
Be careful that there is a coupling between maximal courant number and time step. If you want to run a LES case, you can adjust your courant number in a way that your maximum time step do not exceed 1e-05. Try raising your CFL number as I mentioned, It speeds your running time. I am sure that you can reach to a acceptable result after a few days.
Monitor your maximum time step in a log file to be confident about it. never more than 1e-05.
use this directive for monitoring your results in a log file
  mpirun -np 12 fireFoam -parallel > log
Bobi
Old   October 9, 2013, 06:19
Bobby
Dear Buddies
Does anybody has ever tried to use firefoam code with a mixture of fuel instead of a single fuel. for instance CH4+H2 or C3H8+H2?
If there is any try with successful results, I would be very pleased to be informed. Cause I have some questions to ask
regards
Bobi
Old   September 16, 2014, 19:04
vishal
vishal_s is on a distinguished road
Hello Bobi,
I am sorry.. I don't have much experience in C++ or openfoam. What is "chi"??
vishal_s is offline   Reply With Quote
laplacian foam simulating diffusion through a porous media mcdonalds OpenFOAM Running, Solving & CFD 1 February 1, 2015 16:51
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Simulating diffusion flames with fireFoam babakflame OpenFOAM Programming & Development 1 February 9, 2013 03:21
laminar diffusion flames in OpenFOAM? adhiraj OpenFOAM 3 September 15, 2010 19:16
Diffusion Flames with Flamelet model ,little question. AdidaKK Main CFD Forum 11 November 3, 2009 02:01
