Error during parallel run
Like Tree1Likes
  • 1 Post By alexeym
Old   October 6, 2014, 04:53
Exclamation Error during parallel run
harshawardhank
harsha_kulkarni is on a distinguished road
I have get this error
what should I do
mpirun was unable to launch the specified application as it could not find an executable:
Executable: InterFoam
harsha_kulkarni is offline   Reply With Quote
Old   October 6, 2014, 05:01
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It's
interFoam
not
InterFoam
harsha_kulkarni likes this.
alexeym is offline   Reply With Quote
Old   October 6, 2014, 05:44
harshawardhank
Originally Posted by alexeym View Post
It's
interFoam
not
InterFoam
It's my silly mistake
Old   October 6, 2014, 05:45
harshawardhank
Thanks
Old   October 6, 2014, 05:51
harshawardhank
when I' trying to simulate using ./Allrun
I'm getting an error
/Allrun: 52: ./Allrun: decomposePar: not found
Old   October 6, 2014, 06:02
Alexey Matveichev
Are you sure the environment was set up? I.e. did you source OpenFOAM's bashrc? You can check it by issuing
export | grep FOAM_
if the environment wasn't set up, the output will be empty.
Old   October 6, 2014, 07:18
harshawardhank
declare -x FOAM_APP="/home/ict/OpenFOAM/OpenFOAM-2.3.0/applications"
declare -x FOAM_APPBIN="/home/ict/OpenFOAM/OpenFOAM-2.3.0/platforms/linuxGccDP/bin"
declare -x FOAM_EXT_LIBBIN="/home/ict/OpenFOAM/ThirdParty-2.3.0/platforms/linuxGccDP/lib"
declare -x FOAM_INST_DIR="/home/ict/OpenFOAM"
declare -x FOAM_JOB_DIR="/home/ict/OpenFOAM/jobControl"
declare -x FOAM_LIBBIN="/home/ict/OpenFOAM/OpenFOAM-2.3.0/platforms/linuxGccDP/lib"
declare -x FOAM_MPI="openmpi-system"
declare -x FOAM_RUN="/home/ict/OpenFOAM/ict-2.3.0/run"
declare -x FOAM_SETTINGS="WM_NCOMPPROCS=4"
declare -x FOAM_SIGFPE=""
declare -x FOAM_SITE_APPBIN="/home/ict/OpenFOAM/site/2.3.0/platforms/linuxGccDP/bin"
declare -x FOAM_SITE_LIBBIN="/home/ict/OpenFOAM/site/2.3.0/platforms/linuxGccDP/lib"
declare -x FOAM_SOLVERS="/home/ict/OpenFOAM/OpenFOAM-2.3.0/applications/solvers"
declare -x FOAM_SRC="/home/ict/OpenFOAM/OpenFOAM-2.3.0/src"
declare -x FOAM_TUTORIALS="/home/ict/OpenFOAM/OpenFOAM-2.3.0/tutorials"
declare -x FOAM_USER_APPBIN="/home/ict/OpenFOAM/ict-2.3.0/platforms/linuxGccDP/bin"
declare -x FOAM_USER_LIBBIN="/home/ict/OpenFOAM/ict-2.3.0/platforms/linuxGccDP/lib"
declare -x FOAM_UTILITIES="/home/ict/OpenFOAM/OpenFOAM-2.3.0/applications/utilities
the output is like ablove when I use export | grep FOAM_ command
If environment was'nt set what is the procedure for that
Old   October 6, 2014, 08:25
Alexey Matveichev
Environment seems to be set. What's the output of
which decomposePar
Old   October 6, 2014, 08:26
harshawardhank
I have added below line in $HOME/.bashrc by
gedit ~/.bashrc
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
Is it the right way to set environment ??
Old   October 6, 2014, 08:29
harshawardhank
It shows nothing, when we enter 'which decomposePar'
Alexey Matveichev
gedit ~/.bashrc
Yes, it is.
Old   October 6, 2014, 08:36
Alexey Matveichev
It's rather strange. Maybe OpenFOAM installation is somehow broken (i.e. parallel support was not built). Can you show the output of the following commands:
$ cd $FOAM_APPBIN
$ ls decompose*
Old   October 6, 2014, 11:50
harshawardhank
These are the outputs from above command
bash: cd: /home/ict/OpenFOAM/OpenFOAM-2.3.0/platforms/linuxGccDP/bin: No such file or directory
ls: cannot access decompose*: No such file or directory
Old   October 6, 2014, 12:02
Alexey Matveichev
Mmm... it seems I'm starting to understand what's going on
You've downloaded source tarball, unpacked it into $HOME/OpenFOAM, sourced $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc and now trying to run tutorials? I.e. you've forgotten compilation step.
Old   October 6, 2014, 12:14
Exclamation
  #15
harshawardhank
what I did her download tarballs from OpenSSL
later put in OpenFOAM directory and extract it.
and give command- source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bash
it give following error
bash: /home/ict/OpenFOAM/OpenFOAM-2.3.0/etc/bash: No such file or directory
Old   October 6, 2014, 23:13
harshawardhank
Actually
Terminal is not taking any command related to OpenFOAM, fluent
It has some problem it is not showing different colour for directory, executable
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 14:43
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
