How can you create a dynamic/calculated internalField? |
October 10, 2014, 04:03 |
Martin Pedersen
Rep Power: 11 |
Hi!
I am currently setting up some airfoil simulations at different angles of attack. For this I want to be able to easily rotate the U.internalField to simulate changing angles of attack. Obviously, I could just calculate the new U vector by hand, but it would more practical to automatically calculate the new internalField-vector based on a free stream velocity and an angle of attack. So instead of Code:
internalField uniform (2 0 0); Code:
#include "freeStream" internalField uniform (uInfX uInfY 0); In any case I need to calculate the velocity components in C++ code. I have tried using the codeStream directive, but I keep getting errors. The simplest case I can setup is one without any actual calculations: Code:
internalField #codeStream { code #{ os << (0, 0, 0); #}; }; Code:
Create time Create mesh for time = 0 Reading field p Reading field U Using #codeStream at line 21 in file "/home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U" Using #codeStream with "/home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/dynamicCode/platforms/linux64GccDPOpt/lib/libcodeStream_f4e00eed56f471723793acc5dad98c5aeb257006.so" Creating new library in "dynamicCode/_f4e00eed56f471723793acc5dad98c5aeb257006/platforms/linux64GccDPOpt/lib/libcodeStream_f4e00eed56f471723793acc5dad98c5aeb257006.so" Invoking "wmake -s libso /home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/dynamicCode/_f4e00eed56f471723793acc5dad98c5aeb257006" wmakeLnInclude: linking include files to ./lnInclude ln: failed to create symbolic link `./codeStreamTemplate.C': Read-only file system Making dependency list for source file codeStreamTemplate.C /home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U.#codeStream: In function ‘void Foam::codeStream_f4e00eed56f471723793acc5dad98c5aeb257006(Foam::Ostream&, const Foam::dictionary&)’: /home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U.#codeStream:25:11: warning: left operand of comma operator has no effect [-Wunused-value] /home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U.#codeStream:25:14: warning: right operand of comma operator has no effect [-Wunused-value] '/home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/dynamicCode/_f4e00eed56f471723793acc5dad98c5aeb257006/../platforms/linux64GccDPOpt/lib/libcodeStream_f4e00eed56f471723793acc5dad98c5aeb257006.so' is up to date. --> FOAM Warning : From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C at line 318 Reading "/home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U" from line 18 to line 46 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. --> FOAM FATAL IO ERROR: Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 0 the label 0 file: /home/mpedersen/Documents/internship/OpenFOAM/DU97/DU97_simpleFoam/0/U.internalField at line 0. From function Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 94. FOAM exiting Does anybody have an idea how to solve these errors, or any general tips on how to define a dynamic internalField? I am very new to OpenFOAM and CFD in general, so any help would be much appreciated |
create the file *.foam | phongstar | OpenFOAM | 12 | October 14, 2018 18:06 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 15:22 |
[ANSYS Meshing] is it possible to create virtual edges on the blades | er_ijaz | ANSYS Meshing & Geometry | 0 | November 3, 2013 05:15 |
[DesignModeler] Design Modeller create surface | papis | ANSYS Meshing & Geometry | 0 | October 31, 2013 13:52 |
About create interface! | xinzhiyu2008 | STAR-CCM+ | 2 | August 6, 2010 20:47 |
