[swak4Foam] groovyBC specifying time and spatial varying boundary conditions |
December 7, 2014, 21:34 |
Rep Power: 14 |
Hi all,
I have been using timelines in groovyBC for awhile now and results has been really good for my applications. I am currently planning to take it a step further and vary the boundary conditions in one of the spatial axis (i.e. y-axis). I am not very sure how I should accomplish this. Is it through lookup tables? Since now I will be inputting data that is going to vary with time and the y-axis, am I supposed to put all the data (a 2D array) into lookuptables? Or should/can timelines and lookuptables be used together? TIA |
December 8, 2014, 05:14 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 8, 2014, 05:39 |
#3 | |
Rep Power: 14 |
Sorry I'm not very clear on the second point. Does timeVaryingMappedFixedValue only work if we can separate the function into g(x)*h(y) is that correct? |
December 9, 2014, 07:45 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
As far as I remember timeVaryingMappedFixedValue interpolates in time between sets of spatial data. It can not be combined with grovvy/swak
September 10, 2015, 09:00 |
Clint Bedick
Rep Power: 14 |
Bumping this thread up because I was wondering if anyone has done any additional development work to implement multidimensional lookup tables in swak4foam (groovyBC).
Or alternatively, does anyone know where in the swak source the lookuptable stuff located? I've not been able to find it thus far. Thanks! -Clint |
Physical Reason for stability of Implicit Schemes? | radhakrishnan | Main CFD Forum | 26 | October 3, 2023 22:05 |
LES in DES can't be actived! | shenying0710 | CFX | 17 | January 23, 2014 04:45 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
spatial non uniform boundary conditions | pepe.aero | OpenFOAM Pre-Processing | 4 | November 12, 2012 09:29 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 06:25 |
