how to calculate the porosity flow rate?
Hello I need fast help and unfortunatly i found nothing in my search (thats is unusual :(). My solution doesn't work.
My case is incompressible and isothermal. I have a porous zone where I want to calculate the porosity more or less so that I get a certain flowspeed in that area. I took the equation from the Darcy Forchheimer header file. S = - (mu*d + 0.5*rho*UČ*f) I assumed that S is a force and flow only flows in one direction so I took the U into the brackets. So I thought about setting d to zero and using a bernulli equation to substitute S. S = - deltaP * A =- 0.5*rho*(UČ-UČ_after)*A After substituting this I relocated it to f: f = A*(1-UČ_after/UČ) But it doesn't work. The values are to low. So what all do I wrong. Thanks for every help! |
