how to generate conical geometry in topoSet
Old   January 7, 2015, 08:54
Default how to generate conical geometry in topoSet
Peng Liang
tjliang is on a distinguished road
Hello Foamers,
i am recently struggling with the mesh problems. I want to use toposetdict to generate a cathode, which is built with a cylinder and a cone . I have searched out the document inhttps://openfoamwiki.net/index.php/TopoSet, from which I can only find how to generate cylinder using cylinderToCell. Now I wonder if a cone shaped geometry is also possible using toposet.Any hints from you will be welcome. Thanks in advance.
Peng
tjliang is offline   Reply With Quote
Old   January 20, 2015, 11:15
cutter is on a distinguished road
as far as I know that's currently not possible. I might be wrong though.
The required functionality (coneToCell) can be implemented based on the cylinderToCell cell source with little effort. The code is located at .../src/meshTools/sets/cellSources/cylinderToCell.
Hope that helps.
Cutter
cutter is offline   Reply With Quote
Old   January 20, 2015, 12:43
Matthew Denno
mgdenno is on a distinguished road
Another thought - It seems like something swak4foam could do, although I have never tried.
If I search for "swak4foam swakTopoSource", this thread comes up. Looks like it may send you in the right direction as far as using swak4foam in the topoSetDict file.
http://www.cfd-online.com/Forums/ope...variables.html
mgdenno is offline   Reply With Quote
Old   April 13, 2017, 22:45
Big Orange
bigorange is on a distinguished road
Originally Posted by tjliang View Post
Hello Foamers,
Peng
Hello Peng,
Have you succeed in create a cone shape by using topoSet? If the answer is yes, would you share your method with me ?
Thanks a lot!
Big Orange
bigorange is offline   Reply With Quote
Old   February 6, 2019, 19:50
Honey
Honey is on a distinguished road
Hello Foamers,
Peng
Originally Posted by bigorange View Post
Hello Peng,
Thanks a lot!
Big Orange
Hi!
Did you guys manage in creating a cone shape?
It would highly appreciate if you help me, as well as others who are phasing this problem
Thank you in advance & regards,
Honey
Honey is offline   Reply With Quote
Old   July 17, 2023, 14:46
Smile Cylinder on cone cellzone
Kalle Eng
KalleK is on a distinguished road
Dear all,
I am curious whether anyone has been working on this since the last post. I am looking to create a conical cellzone, or more specifically, a cylinder on top of a cone
KalleK is offline   Reply With Quote
[ICEM] Generate multiply bodies and then mesh them one by one hz283 ANSYS Meshing & Geometry 1 March 3, 2013 15:27
[DesignModeler] problem with import geometry from catia pavilion ANSYS Meshing & Geometry 1 November 23, 2012 10:45
[ICEM] how to generate high quality mesh with this geometry? llrr ANSYS Meshing & Geometry 6 November 23, 2012 05:40
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
