March 16, 2015, 08:33 |
Pre-processing for Windows
Vitor Morais
Dear,
Is there any software pre-processing for create geometry in format ".STL" for Windows version and is compatible with OpenFOAM (blueCFD)? Best regards. Thank's. |
March 30, 2015, 02:12 |
Rep Power: 15 |
Conversion to STL is usually done via plugins in the software that you use to create the geometry. SketchUp, Revit etc have STL Exporters that you can use to create the required STL files. Is there any particular requirement that you are looking for? Regards, Antimony |
March 30, 2015, 16:56 |
Alexander Bartel
Rep Power: 11 |
you also can save files in .stl with paraview. If the mesh is in a type paraView can read, it should work. regards Alex |
DEM - Pre Processing - Joining two separate mesh regions after some iterations | yesaswi92 | STAR-CCM+ | 0 | August 27, 2014 12:03 |
[Q] CHEMISTRY POST PROCESSING takes a long time... | Whitebear | CFX | 3 | August 8, 2014 09:39 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
PRE and POST processing package | Astrid Barros | Main CFD Forum | 6 | November 16, 2000 10:31 |
