Question about k-epsilon turbulence model for a backward-facing step?
Old   March 28, 2015, 16:04
Default Question about k-epsilon turbulence model for a backward-facing step?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello All,
I am doing a validation study on a backward-facing step and trying to implement k-epsilon with proper boundary conditions. The dynamic viscosity for the problem is 1.96*10^-6 N.s/m2, Re 5100, density 1kg/m3, Ux=1m/s, Uy=0. I have made the proper mesh according to y+ NASA calculator. I have 29000 number of nodes for the mesh. Everything is being step properly. Now, I want to implement k-epsilon with a give value of k=0.015m2/s2 and turbulence intensity of 10%. The aim of the study is to compare my data with the reattachment point. I have tried to set up k and epsilon properly. However, the results do not seem reasonable. I am attaching both k and epsilon boundary conditions and would be more than happy if someone of you could help in this regards.
Boundary condtions.zip
tareqkh is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Backward facing ramp - SST k-omega model y+ requirements Crank-Shaft Main CFD Forum 0 May 2, 2013 06:07
backward facing step chelvistero OpenFOAM 0 April 20, 2010 11:48
Backward Facing Step Pete Main CFD Forum 5 June 28, 2000 21:40
