LES 2D multiphase simulation error using imported gmsh mesh
Old   April 13, 2015, 04:09
Default LES 2D multiphase simulation error using imported gmsh mesh
thomas
thomas. is on a distinguished road
Hello all,
I am trying to simulate a multiphase flow using interFoam and using LES for turbulence modelling. I will try to be as accurate as possible regarding the description of the problem, so I will quote all error/warnings messages from terminal.
I would really appreciate your help. Thanks in advance for your time!
So, the geometry file in gmsh is:
// Gmsh project created on Thu Apr  9 09:24:11 2015
el = 1;
pi = 3.14159265;
theta = (pi/4 + pi/2);
theta2 = (pi/4);
r = 40;
r2 = 40+20*Cos(theta2);
Point(1) = {0, 0, 0, el};
Point(2) = {0, 15, 0, el};
Point(3) = {r2*Cos(theta), 15+r2*Sin(theta), 0, el};
Point(4) = {r*Cos(theta), 35+r*Sin(theta), 0, el};
Point(5) = {0, 35, 0, el};
Point(6) = {0, 40, 0, el};
Point(7) = {120, 40, 0, el};
Point(8) = {120, 35, 0, el};
Point(9) = {160, 35, 0, el};
Point(10) = {160, 15, 0, el};
Point(11) = {120, 15, 0, el};
Point(12) = {120, 0, 0, el};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 5};
Line(5) = {5, 6};
Line(6) = {6, 7};
Line(7) = {7, 8};
Line(8) = {8, 9};
Line(9) = {9, 10};
Line(10) = {10, 11};
Line(11) = {11, 12};
Line(12) = {12, 1};
Line Loop(13) = {6, 7, 8, 9, 10, 11, 12, 1, 2, 3, 4, 5};
Plane Surface(14) = {13};
Extrude {0, 0, 10} {
  Surface{14};
  Layers{1};
  Recombine;
Physical Surface("back") = {14};
Physical Surface("front") = {76};
Physical Surface("inlet") = {67};
Physical Surface("outlet") = {43};
Physical Surface("walls") = {59, 63, 71, 75, 31, 35, 39, 43, 47, 55};
Physical Volume("interior") = {1};
After converting the mesh file using gmshToFoam, I get following warning:
--> FOAM Warning :
    From function polyMesh:polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627
    Found 248400 undefined faces in mesh; adding to default patch.
The resulting boundary file looks like this:
6
    back
        type            patch;
        physicalType    patch;
        nFaces          122260;
        startFace       609360;
    walls
        type            patch;
        physicalType    patch;
        nFaces          3496;
        startFace       731620;
    outlet
        type            patch;
        physicalType    patch;
        nFaces          156;
        startFace       735116;
    inlet
        type            patch;
        physicalType    patch;
        nFaces          112;
        startFace       735272;
    front
        type            patch;
        physicalType    patch;
        nFaces          122260;
        startFace       735384;
    defaultFaces
        type            patch;
        nFaces          116;
        startFace       857644;
As I change the type and physical type for front and back to "empty" while leaving the defaultFaces type as "patch" and I try to run interFoam, I get following error:
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for defaultFaces
file: /home/thomas/CFD/OpenFOAM/thomas-2.3.1/run/tutorials/multiphase/interFoam/thomasCaseLES/0/p_rgh.boundaryField from line 25 to line 42.
    From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209.
FOAM exiting
And if I change the defaultFaces type to "empty", I get following error:
--> FOAM FATAL ERROR:
Case is not 3D or 2D, LES is not applicable
    From function cubeRootVolDelta::calcDelta()
    in file cubeRootVolDelta/cubeRootVolDelta.C at line 72.
FOAM exiting
Once again, thank you in advance for reading and trying to help!
thomas. is offline   Reply With Quote
Old   April 13, 2015, 04:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You have forgotten to add one surface into walls patch (see attached image), so they went into defaultFaces and this ended with final error (as for 2D case only front and back should be empty).
Also, you have to edit boundary dictionary (with changeDictionary utility for example), so front and back have type empty, walls has type wall (or your next question will be about wall functions those complain about walls not being walls ).
And finally, why not make hexagonal mesh using transfinite algorithm? The geometry is very simple.
alexeym is offline   Reply With Quote
Old   April 13, 2015, 07:56
thomas
first of all, thank you very much for responding. Your comment helped me to find where I was messing up: I checked the wall boundaries definition and I noticed, that I had surface 43 defined as an outlet and as a wall. In stead of defining surface 43 as a wall, I have to define surface 51 as a wall.
Regarding the transfinite algoritm: that's the next step!
Thanks again!
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Getting the right mesh for simulation dcggames ANSYS Meshing & Geometry 9 January 8, 2013 09:51
Problem w/ vortex ring simulation, mesh coarseness parameters? ESC FLUENT 2 September 4, 2012 10:56
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
