[cfMesh] How can I change the mesh structure generated by cfMesh
Like Tree5Likes
  • 1 Post By franjo_j
  • 2 Post By pici
Old   May 19, 2015, 23:43
Default How can I change the mesh structure generated by cfMesh
Choi Hak Kyu
prodo is on a distinguished road
Now I'm generating the mesh by cfMesh
I can generating mesh around boundary layer like picture 1 by cfMesh
The meshs are merged immediately on upper boundary layer
but, I want generate mesh seems like picture 2, there is little difference.
(you can compare red circle)
so, How can I generate the mesh like picture 2?
there is a option for this ?
thank you
prodo is offline   Reply With Quote
Old   May 22, 2015, 04:27
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
I guess you want to move the transition region away from the boundary layer. Please try refinementThickness option. The is boundaryCellSizeRefinementThickness options valid globally.
I hope this helps you proceed further.
Regards,
Franjo
prodo likes this.
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   June 2, 2015, 06:59
Choi Hak Kyu
Thank you very much, Franjo
It is working very well
Regards,
Old   July 20, 2015, 06:29
Question about cfMesh cartesianMesh objectRefinement
pici's Avatar
Pierluigi Cirrottola
pici is on a distinguished road
Hi prodo, hi Franjo
I' trying to use cfMesh too, and I can say that it is very interesting and fast.
I have this problem: this objectRefinement part of my meshDict doesn't work at all. I don't see any error in cartesianMesh logfile, but refinement doesn't appear.
Can you help me?
Many thanks
Piero
objectRefinement
    centro
    {     type         sphere;
        cellSize    0.1;
        centre        (0 0 0);
        radius        3;    }
    linea1
    {    type        line;
        cellSize    0.2;
        p0            (-7.5 0 8);
        p1            (0 0 0);
        refinementThickness    2.5;    }
    linea2
    {    type        line;
        cellSize    0.2;
        p0            (7.5 0 8);
        p1            (0 0 0);
    verticale
    {    type        line;
        cellSize    1;
        p0            (0 -50 0);
        p1            (0 50 0);
        refinementThickness    10;    }
pici is offline   Reply With Quote
Old   July 20, 2015, 06:43
Choi Hak Kyu
I think, objectRefinement spell was wrong
may objectRefinements is correct
objectRefinement <--
    centro
    {     type         sphere;
        cellSize    0.1;
        centre        (0 0 0);
        radius        3;    }
    linea1
    {    type        line;
Old   July 20, 2015, 08:27
Thumbs up ok
pici's Avatar
    centro
    {     type         sphere;
        cellSize    0.1;
        centre        (0 0 0);
        radius        3;    }
    linea1
    {    type        line;
It is surprising how long I checked my meshDict for some misspell without any result . . . Now it works.
Many many thanks to you, prodo
Piero
Old   July 21, 2015, 09:13
Unhappy cfMesh python tools
pici's Avatar
Hi Franjo,
I read that you are actively involved in cfMesh SourceForge project.
I have a stupid problem: I'm not able to run salomeTriSurf.py.
In effect, I can start the tool, but I don't know how to create the output file.
I read the source code, but, because I'm not so good to program, I didn't understand how to input the fileName.
Can you give me some information?
Thank you in advance
Piero
p.s. I'm running Salomé 7.5.1 on Ubuntu 14.04.2LTS
Old   July 22, 2015, 04:19
Default cfMesh python tools for Salome
Franjo Juretic
Ciao Piero,
Yes, I am the principal developer of cfMesh. However, the scripts for Salome are the contribution from Ivor Clifford.
In order to export the surface from Salome I usually do the following:
1. Generate a triangulation in Salome, within the Mesh module.
2. Import the salomeToSurf.py script. The Load Script option exists inside the File menu.
3. Select the surface you want to export, by highlighting it in the project tree, and write:
triSurf().writeFms("surfaceName.fms")
in the python console.
This executes the script with the selected mesh as its argument, and writes the fms file with the given name into the directory where Salome is installed. You can also provide an absolute path to get the fms file written to the desired location.
I hope this helps you move forward.
Regards,
Franjo
Krapf likes this.
www.cfmesh.com
Old   July 22, 2015, 06:15
Cool Nice !
pici's Avatar
Originally Posted by franjo_j View Post
Ciao Piero,
Regards,
Franjo
Ciao, Franjo
I just tested it (on 7.5.1): it works very well!
Many thanks
Piero
p.s. it could be a good idea to make a sub-forum about cfMesh use . . .
franjo_j and Bazinga like this.
Old   January 13, 2016, 07:40
Javier Anez
javierjap is on a distinguished road
Hi everyone.
I just began using cfMesh on last Monday. And I am also new in OF and Salome.
I followed the steps described below, but I got this message from the python console:
>>>triSurf().writeFms("meshPractice.fms")
Converting SMESH Mesh 'Mesh_1'
Done
Traceback (most recent call last)
File ''<input>'', line 1, in <module>
File /path_to_salomeTriSurf.py, line 344, in writeFms
f = open(fileName, 'wb') #NOTE: file opened as binary to ensure unix-style line breaks
IOError: [Errno 13] Permission denied: 'meshPractice.fms'
I am using Salome 7.6
Please anyone
Thanks in advance
JAP
Ciao Piero,
Regards,
Franjo
javierjap is offline   Reply With Quote
Old   January 18, 2016, 09:00
pici's Avatar
Originally Posted by javierjap View Post
Hi everyone.
Done
Please anyone
Thanks in advance
JAP
Hi Javier,
perhaps you are trying to send your .cms file to a protected directory.
In python console, write:
import os
print os.getcwd()
you will see the actual dir where your are attempting to write.
Write now:
dir="yourdirname"
os.chdir(dir)
where "yourdirname" is complete path of a directory where you have a complete hownership and try to use again TriSurf().writeFms("meshPractice.fms")
I hope it is enough
bye
Piero
Old   January 20, 2016, 12:17
Javier Anez
Originally Posted by pici View Post
Hi Javier,
import os
print os.getcwd()
Write now:
dir="yourdirname"
os.chdir(dir)
I hope it is enough
bye
Piero
Thanks so much Piero for your reply. Although I had found a solution before
Since that was my first time using python console in Salome, I did not know that the scripts need to be located where Salome is being run.
However, I have another question. Have you managed to create smooth boundary layers using cartesianMesh? I mean, I am trying to get similar cell size between the last boundary layer and its neighbor cell.
Attached I sent you two pictures:
The first picture is just a simple case to demonstrate the big difference between the last boundary layer and its neighbor cell, and the second picture both cells are approximately the same size.
Best regards
JAP
File Type: jpg Screenshot from 2016-01-20 17:54:11.jpg (105.0 KB, 126 views)
File Type: jpg Screenshot from 2016-01-20 17:57:46.jpg (123.0 KB, 110 views)
Old   January 20, 2016, 20:08
Franjo Juretic
Best regards
JAP
The explicit control does not exist, yet. Though, you can try to play with the thicknessRatio and the number of layers. This may get you what you want.
Regards,
Franjo
javierjap likes this.
www.cfmesh.com
Old   February 23, 2017, 05:10
Sam
SamHardyUK is on a distinguished road
Hi guys, this is my first post so please be kind!
I created an fms file using the salomeTriSurf.py script and the triSurf().writeFms("draftTube8.fms") function as outlined by franjo_j - this was successful and I have the .fms file in the correct directory and tried to mesh using cartesianMesh and got the following terminal window failure:
Create time
Setting root cube size and refinement parameters
Root box (-2.446 -3.36 -4.096) (5.746 4.832 4.096)
Requested cell size corresponds to octree level 13
Refining boundary
Refining boundary boxes to the given size
Finished refining boundary boxes
Performing automatic refinement
Marking inside/outside.
Number of internal boxes is 100736558
Number of outside boxes is 70662364
Number of data boxes is 52416923
Number of unknown boxes is 0
Killed
This case has been run using a simple .fms file that was created from a merged .stl using surfaceToFMS.
So my question is, why would the .fms file created in salome cause the cartesianMesh to fail? The only change I have made to the fms file created in salome is to change the inlet and outlet from wall to patch and left the main body as wall.
p, li { white-space: pre-wrap; salomeTriSurf.py p, li { white-space: pre-wrap; }
SamHardyUK is offline   Reply With Quote
Old   August 20, 2018, 10:35
Jenna Vergeynst
jenna is on a distinguished road
Ciao Piero,
Regards,
Franjo
The workflow above (but with the script salomeTriSurf.py instead of salomeToSurf.py, are these the same?) is giving me following error:
AtributeError: 'SalomeOutsideGUI' object has no attribute 'getAllSelected'.
I'm using Salome 8.3.0. Anyone an idea what the problem might be?
Thanks!
Jenna
jenna is offline   Reply With Quote
Old   August 22, 2018, 09:27
Jenna Vergeynst
Just posting the solution to my problem above, thanks to Ivor Clifford.
As I was running the script from outside the GUI, the following was needed to be written inside my script:
import salome
salome.salome_init()
from salomeTriSurf import triSurf
triSurf(<object>).writeFms(<filename>)
Jenna
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[GAMBIT] 3D Mesh for complex structure Shinobi ANSYS Meshing & Geometry 40 December 4, 2012 04:30
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
