June 10, 2015, 14:04 |
Boundary Conditions when Using Mirror Mesh
Alex Benjamin
Rep Power: 10 |
Hey!
I am using the mirrorMesh feature to simulate the geometry for a rotating cylinder in an otherwise stationary fluid. I created 1/4 of the geometry and mirrored that twice to get what I need. My question is this; When the mesh is mirrored, are the boundary conditions also mirrored? If so what boundary condition should I impose at the mirrored surfaces i.e. the patches that the original and the mirrored geometry have in common? I am looking for something on the lines of "do nothing and treat it like a regular space in the domain"? Any thoughts? Thanks! |
March 17, 2021, 05:17 |
Bushra Rasheed
Rep Power: 5 |
Hi!
Were you able to find answer for this? Seems like there is not enough information present regarding mirrorMesh. I get two polymesh files when I use mirrorMesh, mesh generation is successful, simulation runs fine but I am not able to view it in paraview. It gives error that points and fields do not match ( points are double of fields because of mirror). I think the simulation it did was for half of the domain and not for mirrored domain. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
