Import temperature data into boundary conditions |
June 30, 2015, 00:48 |
Huynh Phong Thanh
Rep Power: 12 |
Hi all,
I would like to import temperature results *.csv file getting from Paraview at line boundary partitions. In Paraview I got data by filter plot section. The data were made from the big model and different mesh, shape. I used to table file or csv file with type "uniformFixedValue" but it is time-dependence conditions. I would like to import data as list scalar into BCs and not change in time. I also used mapFields directly mapping from big model but it is only import internal fields source to internal fields target value although patchMap in mapFiedlsDict were specified. Does anyone have idea how to import list scalar into BCs? Thank you for help, Thanh Last edited by hiuluom; July 1, 2015 at 11:53. |
July 25, 2015, 11:32 |
Huynh Phong Thanh
Rep Power: 12 |
Sorry for late,
I solved the problems with mapFields utiltity. If in the BCs result had values, it would be got data correspond to BCs. Thanks everybody |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
