decomposePar on a merged mesh
I am working on a rotating mesh simulation that has a rotor mesh and a stator mesh. Using these two meshes, I generated a combined mesh using mergeMeshes command in openfoam. Everything worked without errors and I can view the merged mesh in paraview. However when I attempt to decompose the case for a parallel run, I get the following error messege: Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 24.14 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Reading hexRef8 data : cellLevel Reading hexRef8 data : pointLevel Reading hexRef8 data : level0Edge --> FOAM FATAL ERROR: index 292441 out of range 0 ... 292439 From function UList<T>::checkIndex(const label) in file /home/niranjan/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/UListI.H at line 109. FOAM aborting Any idea what's wrong and how to correct this? Thanks, kcn |
Hi kcn,
Hope all is well. I am currently trying to use mergeMeshes for a different case but I am running into the same error that you faced. Were you able to resolve the problem? Thanks, Marcus |
