axial fan bc
Old   July 16, 2015, 02:56
Default axial fan bc
daniel
leinad is on a distinguished road
Hi
I am looking to setup a simulation of an axial fan in a room, I want to set up the fan as an internal fan so I have a model with a cylinder the size of the fan inside a room.
I am new to open foam can some one point me in the right direction , at this point as far as I understand it I can use rhopimplefoam for the solver?
And interms of boundary condition for the fan I would have to use a cyclic boundary to link the inlet and outlet of the fan ? Or are there alternative methods of setting up a fan bc ?
Also I found this (fanPressureFvPatchScalarField.H) but there is a lack of documentation would this work and how would I implement it ?
leinad is offline   Reply With Quote
Old   July 17, 2015, 10:40
Default TJunctionFan
daniel
Ok so I have done some digging around on the forum and found the TjunctionFan tutorial that uses cyclic bc to define a fan.
I found some parts of the config file that I dont understand, in the system folder there is a file topoSetDic. if some one has time could they clarify how the bc is applied to the two faces and what does the baffleFaces define ?
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Axial fan or blower cooling a hot object with recirculation mariconeagles96 CFX 4 April 18, 2012 08:41
urgent pressure condition for axial flow fan VIPUL FLUENT 0 October 24, 2008 02:01
Axial Fan Russ FLUENT 8 July 7, 2006 13:59
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 17:52
