Ananthakrishnan |
August 19, 2015 03:43 |
setFields zone to cell:solver crashes
I tried using setFields option with zone to cell. There are three zones with three different fluids. After starting the multiphaseInterFoam it crashes immediately.
If I use box to cell method the solver does not crash. Please let me know the mistake in my process.
As seen below the blockmesh contains 3 different zones named cement, mud and spacer. I then use this named zone in set fields
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
//convertToMeters 0.001;
//5 mm column diameter
//10 cm length
//Width of middle square section
//how many cells in the square section
//how many cells from square section to perimeter
// how many cells from top to bottom
vertices
( 1.25 0.0 1.25) // Vertex fiveoclocksqb = 0
(-1.25 0.0 1.25) // Vertex sevenoclocksqb = 1
(-1.25 0.0 -1.25) // Vertex elevenoclocksqb = 2
( 1.25 0.0 -1.25) // Vertex oneoclocksqb = 3
( 1.76776695455285 0.0 1.76776695137989) // Vertex fiveoclockcb = 4
(-1.76776695455285 0.0 1.76776695137989) // Vertex sevenoclockcb = 5
(-1.76776695455285 0.0 -1.76776695137989) // Vertex elevenoclockcb = 6
( 1.76776695455285 0.0 -1.76776695137989) // Vertex oneoclockcb = 7
//zone 1
( 1.25 5.0 1.25) // Vertex fiveoclocksqt = 8
(-1.25 5.0 1.25) // Vertex sevenoclocksqt = 9
(-1.25 5.0 -1.25) // Vertex elevenoclocksqt = 10
( 1.25 5.0 -1.25) // Vertex oneoclocksqt = 11
( 1.76776695455285 5.0 1.76776695137989) // Vertex fiveoclockcb = 4
(-1.76776695455285 5.0 1.76776695137989) // Vertex sevenoclockcb = 5
(-1.76776695455285 5.0 -1.76776695137989) // Vertex elevenoclockcb = 6
( 1.76776695455285 5.0 -1.76776695137989) // Vertex oneoclockcb = 7
//zone 2
( 1.25 30.0 1.25) // Vertex fiveoclocksqt = 8
(-1.25 30.0 1.25) // Vertex sevenoclocksqt = 9
(-1.25 30.0 -1.25) // Vertex elevenoclocksqt = 10
( 1.25 30.0 -1.25) // Vertex oneoclocksqt = 11
( 1.76776695455285 30.0 1.76776695137989) // Vertex fiveoclockcb = 4
(-1.76776695455285 30.0 1.76776695137989) // Vertex sevenoclockcb = 5
(-1.76776695455285 30.0 -1.76776695137989) // Vertex elevenoclockcb = 6
( 1.76776695455285 30.0 -1.76776695137989) // Vertex oneoclockcb = 7
//zone 3
( 1.25 200 1.25) // Vertex fiveoclocksqt = 8
(-1.25 200 1.25) // Vertex sevenoclocksqt = 9
(-1.25 200 -1.25) // Vertex elevenoclocksqt = 10
( 1.25 200 -1.25) // Vertex oneoclocksqt = 11
( 1.76776695455285 200 1.76776695137989) // Vertex fiveoclockct = 12
(-1.76776695455285 200 1.76776695137989) // Vertex sevenoclockct = 13
(-1.76776695455285 200 -1.76776695137989) // Vertex elevenoclockct = 14
( 1.76776695455285 200 -1.76776695137989) // Vertex oneoclockct = 15
blocks
//square block
hex ( 1 0 3 2 9 8 11 10)cement (5 5 20) simpleGrading (1 1 1)
//slice1
hex (5 4 0 1 13 12 8 9)cement (5 5 20) simpleGrading (1 1 1)
//slice2
hex (1 2 6 5 9 10 14 13 )cement (5 5 20) simpleGrading (1 1 1)
//slice3
hex (2 3 7 6 10 11 15 14)cement (5 5 20) simpleGrading (1 1 1)
//slice4
hex (3 0 4 7 11 8 12 15)cement (5 5 20) simpleGrading (1 1 1)
hex (9 8 11 10 17 16 19 18) spacer (5 5 30) simpleGrading (1 1 1)
hex (13 12 9 8 21 20 16 17) spacer (5 5 30) simpleGrading (1 1 1)
hex (9 10 14 13 17 18 22 21) spacer (5 5 30) simpleGrading (1 1 1)
hex (10 11 15 14 18 19 23 22) spacer (5 5 30) simpleGrading (1 1 1)
hex (11 8 12 15 19 16 20 23) spacer (5 5 30) simpleGrading (1 1 1)
hex (17 16 19 18 25 24 27 26) mud (5 5 150) simpleGrading (1 1 1)
hex (21 20 16 17 29 28 24 25) mud (5 5 150) simpleGrading (1 1 1)
hex (17 18 22 21 25 26 30 29) mud (5 5 150) simpleGrading (1 1 1)
hex (18 19 23 22 26 27 31 30) mud (5 5 150) simpleGrading (1 1 1)
hex (19 16 20 23 27 24 28 31) mud (5 5 150) simpleGrading (1 1 1)
//create the quarter circles
edges
arc 4 5 (0.0 0.0 2.5)
arc 5 6 (-2.5 0.0 0.0)
arc 6 7 (0.0 0.0 -2.5)
arc 7 4 (2.5 0.0 0.0)
arc 12 13 (0.0 5 2.5)
arc 13 14 (-2.5 5 0.0)
arc 14 15 (0.0 5 -2.5)
arc 15 12 (2.5 5 0.0)
arc 20 21 (0.0 30 2.5)
arc 21 22 (-2.5 30.0 0.0)
arc 22 23 (0.0 30.0 -2.5)
arc 23 20 (2.5 30.0 0.0)
arc 28 29 (0.0 200.0 2.5)
arc 29 30 (-2.5 200.0 0.0)
arc 30 31 (0.0 200.0 -2.5)
arc 31 28 (2.5 200.0 0.0)
boundary
fixedWalls
type wall;
faces
(5 4 12 13)
(13 12 20 21)
(21 20 28 29)
(5 13 14 6)
(13 21 22 14)
(21 29 30 22)
(6 14 15 7)
(14 22 23 15)
(22 30 31 23)
(7 15 12 4)
(15 23 20 12)
(23 31 28 20)
lowerWall
type wall;
faces
(0 3 2 1)
(0 4 7 3)
(4 0 1 5)
(1 2 6 5)
(3 7 6 2)
atmosphere
type patch;
faces
(24 27 26 25)
(24 28 31 27)
(28 24 25 29)
(25 26 30 29)
(27 31 30 26)
mergePatchPairs
The below image shows the block diagram of the various zones created using the above blockmesh
http://s27.postimg.org/b9np3zo9r/blockzones.jpg
Below is the set fields dictionary
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue alpha.mud 1
volScalarFieldValue alpha.spacer 0
volScalarFieldValue alpha.cement 0
volVectorFieldValue U ( 0 0 0 )
regions
zoneToCell
name "mud";
fieldValues
zoneToCell
name "spacer";
fieldValues
volScalarFieldValue alpha.mud 0
volScalarFieldValue alpha.spacer 1
zoneToCell
name "cement";
fieldValues
volScalarFieldValue alpha.cement 1
/*boxToCell
box ( -4 0 -4 ) ( 4 30 4 );
fieldValues
boxToCell
box ( -4 0 -4 ) ( 4 5 4 );
fieldValues
please let me know what is the correct way of creating mesh with multiple zones and using it in set fields.
Thank you very much
With regards
Ananthakrishnan
